ls swap help
Old Jul 19, 2009 | 07:17 PM
bradennicely's Avatar
Icon6 ls swap help
I have a 91 civic std, I just recently stared an ls swap. I've been told by a couple of different people that all i need is and 88-91 civic/crx si engine harness?
If i was to do that, would it be easier to get the cabin harness as well and just plug and play? thank ahead for the help
Old Jul 19, 2009 | 07:29 PM
ryanevansoh's Avatar
Default Re: ls swap help
you need to modify your stock harness with parts from the si harness. look up mpfi swap in the faq
Old Jul 19, 2009 | 07:40 PM
i understand that i can do that, but i have a si the shell is just crap. would it be easier to just use that harness?
or even use the si cabin harness, and a da engine harness?
Old Jul 19, 2009 | 08:11 PM
D16SiHatch's Avatar
you can use the si engine harness if you also use the si cabin harness with it. you can't mix and match between models (std,si,etc) or chassis (ed,da).
Old Jul 19, 2009 | 10:04 PM
truth. if your harness is messed up i say why not? just switch out the cabin harness and that will work too
Old Jul 20, 2009 | 03:58 AM
jhammond_82's Avatar
Reject Papi
sure if you have it, might as well use it.
BigbamaBen
Nov 6, 2011 01:50 PM
91CRX-T
Aug 17, 2011 01:16 PM
EF7
Sep 25, 2006 09:06 AM
91H4hatch
Sep 8, 2006 08:14 PM
bbrian
Oct 22, 2005 11:18 PM
