stock tach reading 2000 rpm too high?
Old Jul 19, 2009 | 06:55 PM
coot_er's Avatar
Default stock tach reading 2000 rpm too high?
my tach is not reading right. it doesn not bounce at all but at 70 mph in 5th gear it reads 5500 rpm. When i start the engine up and its cold, it will go up to 3000 rpm before easing down to 1500. it acted weird like this for two days, then it was fine for one, and now it has been messed up for the past 3 days. I did a search put most people problems involved a bouncy tach mine is not bouncing at all.
Old Jul 20, 2009 | 03:29 AM
coot_er's Avatar
Default Re: stock tach reading 2000 rpm too high?
Anyone?
Is it most likely the tach itself or something in the distributor? the only thing is, from doing a search, it sounds like when the ignitor is going out it is more of a bouncing tach
Old Jul 20, 2009 | 03:54 PM
coot_er's Avatar
Well, I changed out the distributor with a good one and the tach is still off.
Old Jul 20, 2009 | 04:07 PM
Turbo Dan's Avatar
when its revving to 3k when its cold does it sound like 3krpm?
when its warm what does the tach show?
easy way to find out if the tach is reading too high....in first gear go very very slow, in gear on the brakes if you have to just to go slow like to a crawl.
if you are reading 1k rpm or whatever the car feels like it should be, then its correct.
if the car is going slow and almost shuttering and still reading 2k rpm something is wrong.
Old Jul 20, 2009 | 07:28 PM
coot_er's Avatar
It sounds normal. if you didn't look at the tach you wountn't know anything was wrong. no weird noises or like it is reving high. still accelerates good/same
when it warms up it idles at 2000
going down the road at 70 mph the tach reades 5500 but sounds normal (~3250?)
Old Jul 21, 2009 | 01:49 PM
coot_er's Avatar
anyone?
Old Jul 21, 2009 | 01:55 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
So get a multi-meter with a tach setting and check the actual RPM off of the distributor and then compare to your tach.
Old Jul 21, 2009 | 05:11 PM
grog's Avatar
has your tach always done this? If it has and its consistently off by 2000 rpm then you can adjust the needle on the tach, i've done it using hondata to reference the correct rpm. let me know if you want more info on this.
You didn't give a very clear answer to Turbo Dan's question. Yes or no....... Does it sound like 3000 RPM when the tach reads 3000 RPM. Please dont say normal.
after re-reading your post i would guess that your tach is on the fritz (going bad)
You can get another cluster from a junkyard and just swap the tach over to your original cluster.
Old Aug 23, 2009 | 04:35 AM
aernst's Avatar
New User
Originally Posted by coot_er
anyone?
I'm having the identical problem. Noticed that when I turned on the ignition switch without starting the car the tach would jump up to 1500 to 2000 rpm's.
I'm still investigating as you are, the engine itself sounds normal while driving though the tach is pretty scary - never thought my engine would rev past 6,500 not it's impressive at 8,500 well into the red before shifting (auto trans).
If I discover anything I'll repost but logically I'm thinking it's a tach/electrical issue and not the engine performance itself.
Old Jul 8, 2010 | 11:49 PM
milanopreludevtec's Avatar
DID ANY ONE FIGURE THIS OUT IT IS VERY ANNOYING AND I CANT FIGURE IT OUT HELP PLEASE!!
Old Jul 9, 2010 | 08:28 AM
Nooch's Avatar
Damn, 1 post in and CAPS LOCK is stuck on already. This kid's a natural.
Did you check what the other people throughout the thread said?
Old Apr 1, 2020 | 04:45 PM
dlmechanic's Avatar
I have been having the bouncing tach issue which I just resolved by installing a new ignition coil. It runs smoothly and the tach doesn't bounce at all. However, now my rpms are too high, exactly as you describe. I'm not sure what to blame. Maybe the ignition module itself?
Rotten Egg
Aug 24, 2009 10:20 PM
lexusgui
Jul 27, 2008 07:54 PM
BiG Chris
Oct 11, 2004 05:58 AM
nkSi
Oct 3, 2001 05:39 PM
