couple jdm integra type r questions
From: down the street,bythe river in the van, co, united states
i recently bought a jdm rhd integra type R 96 spec
anyways i want to know what floor mats came stock in this year and model?
what trunk mat came with it? is the trunk mat the checkered one like the usdm one?
and does the usdm itr clock fit the jdm??
and i know this itr came with a arm rest delete is there a difference in any of the years of arm rest??
also does the usdm itr climate control fit the jdm one??
any help is appreciated!! thanks!!
Not sure about the mats, but the clocks are all the same, all the JDM models came with the delete and all the climate controls fit into other integras.
cuz for some reason the usdm clock wont fit right in there
like its a little small the usdm one
Pretty much what jdmeg6b18b wrote,
The ones I've seen had the standard JDM mats, with the connector mat between the two rear mats.
Plain grey.
It should as it's consistent between all the other DM's I've seen. It can be a tight enough squeeze though. I would suspect that in a very hot climate the dashboard may warp slightly and that might make it look like it wouldn't fit. Hell I know it fits, I posted one I had to a lad in New York with a USDM one.
None of the JDM R's came with an armrest.
I would presume so, unless there was a LHD/RHD issue maybe?
As far as difference between the years on the armrest they were all the same, but the newer models had the plaque that said 98 spec etc. that covers the two screws.
yeah i was looking at that on passwordjdm
anyone ever ordered from passwordjdm??
or anyone know where i can get the armrest from
JDM R's don't come with floor mats or trunk mats as standard equipment. There are all optional unless you are got the Rx. Floor mats have a Type R emblem on them with a little ring that allows you too hook them into a little plastic pin on the floor.
you know where i can get the Rx model floor mats??
Rx floor mats are the same as the regular R floor mats...its just that the RX came with them standard, where you would usually have to buy them as a dealer option. I can get used ones but they usually aren't in great condition.
By the way, they also come in red too.
Rishiras
Sep 25, 2005 12:51 PM
