Si Door Conversion
Old Aug 23, 2002 | 01:58 AM
bfong13's Avatar
Default Si Door Conversion
I have a 2000 DX H/B and am in the process of converting the doors (non-power) to Si doors with power (mirrors, windows, and locks). I have obtained the lock mechanism w/motor, window mechanism w/motor, door wire harnesses, electric side mirrors, and mirror control module.
My question is: What else do I need to make it work? I would think that there would need to be some type of cable harness that runs between the two doors or something like that.
Old Aug 23, 2002 | 07:04 AM
YumVTEC's Avatar
Default Re: Si Door Conversion (bfong13)
If you want it OEM you need to get the whole dash harness from a 99-00 EX or Si. I'm in the middle of the same conversion. I have an Si dash harness that I bought from a junk yard, I'm just not looking forward to pulling my dash out, then swapping harnesses.
-T
Old Aug 23, 2002 | 08:01 AM
dose's Avatar
Default Re: Si Door Conversion (YumVTEC)
switching a dash harness is pretty easy.i had to do it to a dash with an automatic wiring harness and put mine in
ovsrcivicek9
13
Feb 1, 2013 07:00 AM
delsolo95
Jun 5, 2011 08:26 PM
kgibson16
Jun 6, 2010 10:36 AM
SILENTJ95835
Oct 17, 2008 06:02 AM
