Transmission & Drivetrain Gearboxes, Differentials, Clutches
Synchros for a JDM ITR tranny?
Old Jul 19, 2009 | 11:06 AM
EM1Guru's Avatar
Default Synchros for a JDM ITR tranny?
is there any place that can get them? I need 1st + 2nd. I was told I couldnt use USDM synchros since the countershaft is different on the 4.7 FD.
Old Jul 19, 2009 | 12:01 PM
Honda Bull's Avatar
Default Re: Synchros for a JDM ITR tranny?
Yes. You can use USDM synchros. Order for any B-series VTEC trans (92-00 B16, 92-01 GSR, 96-01 ITRs).
Synchrotech (formerly Gearspeed) is the most common aftermarket synchro supplier. Or any Honda/Acura dealer, though they will typically come with the sleeve/hub sets.
Old Jul 21, 2009 | 12:51 PM
Gearspeed-Performance's Avatar
Just as Honda Bull said..they are the same.
Old Jul 21, 2009 | 09:55 PM
Mista Bone's Avatar
D Tranny Guru
uh, hang one a minute.......don't think B16 used the double synchro second gear setup
Old Jul 22, 2009 | 11:48 AM
Honda Bull's Avatar
^^^ All large shaft (94-01 hydro and 92-93 cable GSR) B-series VTEC trans utilize the dual cone 2nd gear synchro.
LS does not. And the LS uses different 3-4 pieces for synchro/sleeve/hub/shift fork.
Old Jul 23, 2009 | 03:27 PM
EM1Guru's Avatar
There for Id have to use GSR 1-2 gears, correct?
Old Jul 23, 2009 | 04:28 PM
B16 Hydro(or cable YS-1 only) & GSR use the same exact synchros
goldenhatch13
Sep 9, 2008 04:11 AM
USDM EG
Dec 10, 2007 07:03 AM
JohnnieChimpo
Apr 9, 2006 02:10 PM
andyboy
Jul 20, 2004 09:26 AM
