Weight of 1988 STD Civic Hatchback Thank you
Old Aug 23, 2002 | 01:03 AM
Erik_Pb_Foot's Avatar
New User
Default Weight of 1988 STD Civic Hatchback Thank you
beuler? beuler?
EDIT: And while we're at it, what are the stats on this beast of a car? HP? Torque? Fuel Economy? CR? Thaaaaaanks
Erik
[Modified by Pb_Foot, 5:03 AM 8/23/2002]
Old Aug 23, 2002 | 02:37 AM
93eg-EKhybrid's Avatar
Default Re: Weight of 1988 STD Civic Hatchback Thank you (Pb_Foot)
I believe that the weight is about 2,041 lbs. if not exactly then it is within 50lbs. + or -. Horsepower is a whopping 70 hp, and I'm not exactly sure on the torque. It is supposed to get 35 mpg. Hope that helps your decision to go to a zc, B16, B18, B20, or H22.
Old Aug 23, 2002 | 05:21 AM
CWBETB's Avatar
Anyone have a idea what the weight of a 90 Civic DX would be with power steering?
Old Aug 23, 2002 | 06:33 AM
EF_LSVtec's Avatar
Default Re: Weight of 1988 STD Civic Hatchback Thank you (CWBETB)
Hatch
STD - D15B1 ~70hp
DX ED6 D15B2 ~92hp
Si ED7 D16A6 ~108hp
or check this site: http://www.carpage.tmfweb.nl/specs.htm
Old Aug 23, 2002 | 07:15 AM
OldSchoolHatch's Avatar
Hey, who says he wants to do an engine swap? Maybe the 70hp is plenty fast for him and any more would be too much to handle...
Old Aug 23, 2002 | 07:38 AM
New User
Default Re: Weight of 1988 STD Civic Hatchback Thank you (OldSchoolHatch)
the 70 hp's 38 mpg i got last week is more than enough for a beater. i've got an integra for when i want to go fast, that's the whole reason i've built it. in the next 6-12 months i'll be done fixing her cosmetically and getting the stereo down how i want it... then it'll be time for the b20 swap.
Erik
Old Aug 23, 2002 | 07:43 AM
martini's Avatar
70 hp is more than enough to get yourself in trouble in a rally race.
Old Aug 23, 2002 | 09:13 AM
EF_LSVtec's Avatar
[quote]i've got an integra for when i want to go fast[quote] I thought it was really fast, but when you said you're putting a B20 soon...I guess its slower than a B20 now, what you got under the hood?
Old Aug 23, 2002 | 09:16 AM
Mugen Dom's Avatar
Default Re: Weight of 1988 STD Civic Hatchback Thank you (89B16HB)
the 88 std has nothing at all on it i mean nothing its more liek 1941 maybe less ill loook for an exact # but its close to the hf in weight
Old Aug 23, 2002 | 09:36 AM
New User
Default Re: Weight of 1988 STD Civic Hatchback Thank you (EF_LSVtec)
The integra is no joke. I've got an easy $20k under the hood in parts alone... not to mention tuning, fiberglass, safety equipt, suspension, etc... I am wanting to do a B20 swap in my beater which is the 88 std hatch. not in any hurry since i'm just now finishing paying off my integra and money will be somewhat tight for a couple months.
-Erik
Old Aug 23, 2002 | 10:01 AM
EF_LSVtec's Avatar
Coo...I heard that before (paying off integra)...B20 would be bad on your STD keep us posted.
Old Aug 23, 2002 | 10:08 AM
slywfbpsi's Avatar
That site isn't too acurate it, say there that the b16s are 150 hp and 144 lb ft of torque.
Old Aug 23, 2002 | 02:01 PM
714phil's Avatar
Default Re: Weight of 1988 STD Civic Hatchback Thank you (slywfbpsi)
b16s 144 lb ft of torque.
haha
Old Aug 23, 2002 | 04:44 PM
New User
Default Re: Weight of 1988 STD Civic Hatchback Thank you (STD ONEpointSIX)
the choice would be obvious if that was true. the site had great intention and was layed out very nicely, but someone needs to critique it a little.
How much harder would the b20 swap be in the hatch when compared to a b16 or b18 swap? i'm assuming the motor would have to be mounted quite a bit lower than the other b-series.
-Erik
Old Aug 23, 2002 | 05:01 PM
Jeff 360's Avatar
I'll post the pic from the weigh station next time I go but last time I went, I was at 1,840 lbs. I was quite pleased with the results of gutting out my car, and tearing this and that out. Oh yeah this was at a Washington State Patrol weigh station off of I-5 so I know it's calibrated quite well.
Old Aug 23, 2002 | 05:41 PM
EF_LSVtec's Avatar
B20 is exactly the same as B18, block and head sizewise. Only difference is the piston diameter and intake manifold. I would assume the same procedure in mounting the B18 would apply to the B20.
Old Aug 23, 2002 | 09:57 PM
New User
thanks for that answer. i was being led to believe by a local honda-tech guru wanna be that the b20 was actually larger in size and required the subframe to be slightly modified MORE so than if going with a b series. erik
Old Aug 24, 2002 | 06:23 AM
USDM 4G VTEC's Avatar
i just took my stereo off and the pass seat. and my car weighted 2040.. the stock weight for the STD's are 2167 or somewhere around there.... go look at http://www.hondaswaps.com
Old Aug 24, 2002 | 07:02 AM
Mugen Dom's Avatar
Default Re: Weight of 1988 STD Civic Hatchback Thank you (JDM EF9)
the 88 is a totally different car than teh 90 ur car is a pig compared to teh 88 teh 88 doesnt have as much bumper reinforcements teh door reinforcements arent there as hte seatbelts are on the pillar....even the exhuast is smaller...and less tar **** in side teh car...
Old Aug 24, 2002 | 07:08 AM
Mugen Dom's Avatar
from car and driver teh 1988 civic Curb weight 1950-2400 lbs so the leightest HB to teh heaviest 4dr std 1950 im pretty sure car and driver is accurate and teh hf was 1850
[Modified by jdmb18hatch, 11:09 AM 8/24/2002]
Old Aug 27, 2002 | 06:07 PM
StorminMatt's Avatar
Default Re: Weight of 1988 STD Civic Hatchback Thank you (jdmb18hatch)
I have a 1988 Civic STD. And according to the factory Honda manual (which I was lucky enough to get with the car!), this car weighs 1989 pounds without A/C. If you have A/C, add another 45 pounds. This car has actually had quite a few engines while in my hands - the original 70HP (83ft-lb torque) STD motor, a D16A6 (from my old CRX SI), a B18B, and now a B20Z. Honestly, the B20Z is the best thing that ever happened to that car. With 141HP, 129ft-lb torque (both measured at the wheels), that car flat out FLIES! It is really fun to have a scrappy looking Civic that can lay waste to a stock 5.0 and just about any other Honda out there. In fact, there are not many cars that you commonly see that are faster.
[Modified by StorminMatt, 3:09 AM 8/28/2002]
DeadVet
Jul 4, 2005 08:29 AM
Slow96RedEk
15
Mar 23, 2004 09:11 AM
1ntensiveVTECivic
Jun 19, 2003 08:34 PM
SwitchCabNine
May 11, 2003 11:07 AM
Giuseppe
Dec 28, 2001 02:44 AM
