head gasket? thermostat housing? help please!!!
Old Jul 19, 2009 | 04:29 AM
SoCalHatch's Avatar
Default head gasket? thermostat housing? help please!!!
hey guys well im kinda worried. right now my motor(b18c) is going thru coolant like nothing and its over heating...quickly. yesterday i blew the upper radiator hose into two pieces. so that has been replaced and the radiator and resevoir filled with coolant.
what i dont know is why it keeps going thru coolant so fast without any leaks. it will literally go thru the whole resevoir of coolant just going around the block. there is no smoke at all being emitted from the car and before work i bought a new thermostat housing to see if that will fix the problem after i get off. does it sound like the head gasket at all??? any advice or input appreciated...thanks, carey
Old Jul 19, 2009 | 04:48 AM
zXeX's Avatar
Default Re: head gasket? thermostat housing? help please!!!
If it isn't blowing it out the pipe .. it only has one other place to go .... Check The Oil...
Old Jul 19, 2009 | 05:05 AM
SoCalHatch's Avatar
thanks... explain what to be looking for please. literal coolant in the oil???
Old Jul 19, 2009 | 05:11 AM
Kchambers's Avatar
The oil will be miscolored on the dipstick
Old Jul 19, 2009 | 05:17 AM
tw1tch's Avatar
If the oil is milky looking it's the head gasket.
Old Jul 19, 2009 | 05:20 AM
SoCalHatch's Avatar
thanks guys im going down to autozone tomorrow cus they have that free head gasket test so we shall see what happens. any ideas on what else it could be if not the gasket?
Old Jul 19, 2009 | 05:42 AM
tw1tch's Avatar
The car might not leak just sitting there but it could leak while the motor is on. Sit in the car with it running and rev it up, then get out and look underneath it. If nothing is leaking then I'd bet for sure it's the hg. You could have a leak that shoots it out under loan and never notice it.
GeneEllis
Aug 29, 2013 06:06 AM
Kgill23
Aug 30, 2010 03:14 AM
Civiclized
Nov 23, 2009 12:35 PM
honda_hackett
Sep 8, 2009 01:45 PM
A Tribe Called Honda
Feb 21, 2008 03:19 PM
