Rack & Pinion Identification...!!!
Old Jul 19, 2009 | 02:26 AM
BiG ChOr!Zo's Avatar
Default Rack & Pinion Identification...!!!
I already searched the faq and cannot find anything about the rack and pinion for a ef...Anyways I traded some guy off of craigslist a rice cannon muffler for a manual ef rack and pinion that needs to be rebuilt...I was wondering if you can tell in the pics provided if it really is indeed for a ef and if i can use it on my ef2 with power steering...My suspension is all shot up and I figured it would be better to rebuilt this rack and pinion since it only costs $55 to rebuild out in Los Angeles at a shop...Any info would be appreciated
Old Jul 19, 2009 | 09:51 AM
black0hatch's Avatar
Default Re: Rack & Pinion Identification...!!!
the pictures kinda suck but it looks like an ef rack. and no you cant run power steering on it. theres really nothing to rebuild a non power rack is super simple and you could do it yourself and save some money. mostly the plastc bushing inside them wear out and you can feel the slop in it. and then replace the inner and outer tie rods.
Old Aug 21, 2009 | 01:09 AM
anybody got a diy of how to rebuild this bad boy...also if you can tell me which part numbers in the diagram to get for this manual rack...Inner and outer tie rods have already been ordered...!!!
Old Aug 21, 2009 | 06:22 AM
JOE BD-0's Avatar
You should replace the #10 rack bushing. Check Tyson's FAQ thread for more info.....
I'd like to know how to tell the steering racks apart from the outside???? ( si or dx?)
Thanks H-T for more info.....Good Luck
Old Aug 21, 2009 | 01:48 PM
Old Aug 21, 2009 | 02:37 PM
frank_el_tanke's Avatar
Originally Posted by BiG ChOr!Zo
from what i have read the si and dx rack and pinion are the same...!!!
they are not the same. the si has longer teeth on the pinion, not sure about the rack, but the internal housing might be a little different as well.
it will still bolt up fine.
Old Aug 21, 2009 | 02:41 PM
i just need to know if this is worth rebuilding since i got power steering in my ed3 and need to know which parts to get for it from the diagram...!!!
Old Aug 21, 2009 | 03:06 PM
if your inner tie rods are ok, then all you need is #10 rack end bushing and #7 pinion seal. and of course, boot covers.
Old Aug 21, 2009 | 03:10 PM
thanks...thats what i needed to know...!!!
Old Aug 21, 2009 | 07:48 PM
1whiteSE's Avatar
which has the tighter turning radius?
Old Aug 21, 2009 | 09:56 PM
i believe the non si steering gear box has the shorter lock to lock.
Old Aug 21, 2009 | 10:46 PM
efkid90's Avatar
where did you order your outer tie rods?
i needa replace mine,i tried the other day and dam its a b*&ch
to take off the outer tie rod espically the nut on #11 and 34
Old Aug 22, 2009 | 03:22 AM
1whiteSE's Avatar
Thats funny how the non SI are shorter... on the 3rd Gen Civics/1st Gen CRX the HF racks are shorter lock to lock than the SI...
Old Aug 22, 2009 | 04:52 PM
i ordered everything from www.rockauto.com 3 days ago...All Moog suspension for 3 times less than OEM and that includes a lifetime warranty unlike the 12 month warranty for OEM
Old Aug 23, 2009 | 10:28 AM
1whiteSE's Avatar
Thats good to know, now I have to find a rack
Old Aug 23, 2009 | 12:36 PM
Clipsed's Avatar
38 is the bearing that needs to be repressed onto the pinion gear.
Old Aug 23, 2009 | 05:29 PM
Tyson's Avatar
no.
Old Aug 23, 2009 | 11:52 PM
Clipsed's Avatar
They aren't the same, but I have an STD gear box here which is the same as the DX. Dunno what my OTHER steering rack is, but I will compare the two to see if there are any differences in them.
Old Aug 24, 2009 | 12:55 AM
Tyson's Avatar
DX, STD, HF are all the same.
Si (civic and CRX) will have VWR stamped on it. meaning variable.
the housings and pinions are different between the two, not interchangeable internally, meaning you cannot put a quaife rack in a Si steering rack since it was made to fit a DX (et al.) rack. but it will swap into the same crossmember just fine.
as for a power steering rack, it is "quicker" but i dunno if its worth any effort to put in, swap crossmembers or kludge it with any rubber spacers.
Old Aug 24, 2009 | 01:00 AM
where will that VWR be stamped at and if it does what the hell does it mean...all i care about is if this manual rack is gonna be worth it to swap out my power steering rack or not...!!!
Old Aug 24, 2009 | 01:39 AM
Fo-Do Fanatic's Avatar
Yes your NON-PS rack will fit right on it. That stamp means variable which I believe it means it's the PS rack instead of the NON-PS rack. Correct me if I'm wrong.
Old Aug 30, 2009 | 01:18 AM
After searching for a DIY after almost 2 months I finally found what I was looking for...!!!
Old Aug 30, 2009 | 11:30 AM
KWayRacing's Avatar
Why would you want to lose PS?
Old Aug 30, 2009 | 01:45 PM
just extra parts that i would have to replace when they go bad...besides i eat my spinach and wont have any problems turning the wheels with a manual rack
Mike_ef
May 7, 2012 03:47 PM
SC_HOBD_1816
12
Feb 5, 2009 05:49 PM
rotten
Mar 25, 2007 07:50 AM
Eggman
Dec 12, 2001 07:30 PM
Eggman
Dec 12, 2001 05:46 AM
