wat is that this called
That's a cornering light. Also known as an intersection light or high speed turning light. Some people call them side fog lights too, but that's an odd term that I've never seen used by anyone besides Honda enthusiasts.
Intersection lights are placed on the front bumper (or in the side of the headlight housing) of some vehicles either as standard or optional equipment. All the Hondas that have them have them as optional equipment.
When you have your headlights on and your turn signal on, that cornering light on that side will light up. It doesn't flash. It holds on. When you turn the turn signal off or it cancels itself the cornering light stays on for about a second and then turns off.
They're to help light the way on dark side roads and driveways and aid in getting the attention of other drivers when you want to turn or merge.
They only came on 5G Accords in the US, but were available on 6G Civics and 1G Odysseys in Japan. Some older models (Legends, 4G Accords) had the same thing also, but with a slightly different shape that's more square.
The car shown has the older style ones on a newer style vehicle. That's wrong. That car should use the ones that are more rectangular (wide) and replicate the angle of the wheel well more.
The ones on my car are the ones that the car above should use.
Yup, its a JDM Intersection lights found on Japanese CD5 Accords. Alot of Honda enthusiasts used them no Civics, etc. I have a set on my CD5 Accord; view my garage for more pics.
I was told by one guy that they came on 3G Integras in Japan too, but I've seen nothing to prove that.
Ah, I didn't know they would make them for the 3rd Gen Tegs. Only if there's proof like you said and I've yet to see some too.
Well I assumed that this was a 95 (though I'm probably wrong as I am not an Accord guy) But here is the list I found. Being that the bulb is a 168 listed, that's a fairly big bulb for a fender marker. But if it is a JDM thing then I'm probably wrong there too. Here is the listings I found
1995 HONDA Accord (Except wagon)
Low beam headlamp
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006EB EcoBright - Your Environmental Choice
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005EB EcoBright - Your Environmental Choice
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Parking light
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
7440
7440ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
7440LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear turn signal
1156
1156ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
7443
Stop light
7443
High mount stop light
7440
License plate
168
Back up light
1156
Front sidemarker
168
Rear sidemarker
7443
Ash tray
74
Map light
DE3022
Dome light
DE3022
DE3175
DE3175LL Long Life Upgrade: Up to twice the life of the standard lamp
7443LL Long Life Upgrade: Up to twice the life of the standard lamp
Step/Courtesy light
DE3021
Trunk/Cargo area
DE3021
Instrument-general
74
PC195NA
PC37
Low beam headlamp
9006
High beam headlamp
9005
Parking light
168
Front turn signal
7440
Rear turn signal
1156
Tail light
7443
Stop light
7443
7440
License plate
168
Back up light
1156
Front sidemarker
168
Rear sidemarker
7443
Ash tray
74
Map light
DE3022
Dome light
DE3022
DE3175
Step/Courtesy light
DE3021
Trunk/Cargo area
DE3021
Instrument-general
74
PC195NA
PC37
The bulb used in mine is an 1157 IIRC.
A 168 is the same size as a 196. They're usually the smallest (or damn close to) bulb sold in chain auto parts stores.
I have a USDM 1996 Accord Accessories Manual here that shows the cornering lights on the first and second pages.
In Japan they also did come on '96-'00 Civics.
From the Honda Access Accessories Catalog:
Originally Posted by Honda
CORNERING LIGHTS illuminate dark driveways and hard-to-see turn-offs.
ACTIVATED BY YOUR TURN SIGNAL
Easy to use, no special switch needed
SIDE-MOUNTED LIGHTS
Enhance driver's visibility
PLUG-IN CONNECTOR
Require no wire splicing or cutting for better reliability
SPECIAL HOUSING
Resistant to water, impact, and corrosion
INTEGRATED DESIGN
Factory-installed appearance
SIDE-MOUNTED LIGHTS
PLUG-IN CONNECTOR
SPECIAL HOUSING
INTEGRATED DESIGN
if anyone is interested in doing them they have ones kinda like them on the 97 to 01 crv. mine has them for the rear bumper too that are red. but as you can see they are amber in the front. im sure if you buy them you could just trace them out on the bumper. they just click right in. they do light up too.
Bone Stock
Audio / Security / Video
Sep 9, 2005 08:01 AM
tinhquaygot4ever
Dec 20, 2001 06:19 AM
