help car runs but not well anymore
Old Jul 18, 2009 | 06:20 PM
oldschoollove's Avatar
Default help car runs but not well anymore
so i got my car runing after the mpfi swap and today i had been cleaning up my wireing and had pulled a spark pulg well the car was running and now its idles off and its not running well and theres white smoke comeing out the exhaust and im geting a code 16 for fuel injectors ....what could it be im pissed i just got it running so any thing will help
Old Jul 18, 2009 | 07:08 PM
ryanevansoh's Avatar
Default Re: help car runs but not well anymore
i would say double check your wiring to the injectors
Old Jul 18, 2009 | 08:03 PM
BiG ChOr!Zo's Avatar
check main relay and reset the ecu...!!!
Old Jul 18, 2009 | 08:05 PM
but the car was running fine befor i pulled the spark plug wire now it idles good for like 2mins then get bad and sounds like it want to shut off ...so could it be that maybe i missed up one of the spark pulgs when i pulled the wire
Old Jul 18, 2009 | 08:06 PM
ok ill ck the main relay tomorrow dose anyone know how much one run new
you might of damaged the spark plug wire when you pulled it...i had the same problem in my cb7 and it turned out that i needed new spark plug wires...!!!
Old Jul 18, 2009 | 08:08 PM
cool thats what im thinking well ill have to ck them tomorrow to dark out lol if its not that ill be back lol trying to get the car good and runing for the ef meet
Old Jul 18, 2009 | 08:10 PM
try to get oem when you replace the wires, always has best spark even though they cost a little more. and way more reliable
Old Jul 18, 2009 | 08:12 PM
kool...i get a code 16 all the time in my ef but im just to lazy to replace my wires because im gathering other stuff for my future zc swap...i have a set of cheap *** kragen wires that are falling apart but all i do is swap main relays and reset my ecu and im good to go
Old Jul 18, 2009 | 08:14 PM
Originally Posted by BiG ChOr!Zo
kool...i get a code 14 all the time in my ef but im just to lazy to replace my wires because im gathering other stuff for my future zc swap...i have a set of cheap *** kragen wires that are falling apart but all i do is swap main relays and reset my ecu and im good to go
you mean code 16? code 14 is the code for the iacv
Old Jul 18, 2009 | 08:15 PM
my bad type o...yeah code 16
Old Jul 18, 2009 | 08:41 PM
thanks every one will be looking into it tomorrow
Old Jul 18, 2009 | 11:45 PM
TheEf2Kid's Avatar
check your o rings also. could be leaking out of one.
Old Jul 19, 2009 | 10:15 AM
so a leaking o ring could cause this too ....i ck myspark plug wires and they are all ok so im going to replace my spark pulgs ....but would that cause the code 16 cause the car smokes alot now after i had pulled that plug wire as it was running
Old Jul 19, 2009 | 03:20 PM
sbarmann's Avatar
I've seen a clogged fuel filter cause a code 16 (fuel injector). OBD0 aren't very accurate to pin point the problem. Could be some type of fuel delivery problem. Just a thought though.
mr_munro
Jul 25, 2012 10:43 PM
MagicalMike
Nov 26, 2011 03:23 PM
ProjectEvilEj2
Jan 1, 2009 08:10 AM
djviet2000
May 13, 2007 06:50 PM
virusiidx
Jan 18, 2005 10:11 AM
