B20 Vtec shopping list. Tell me what you think.
Old Jul 18, 2009 | 05:33 PM
blacc_ej1's Avatar
Default B20 Vtec shopping list. Tell me what you think.
B20z Block
B16 Tranny
B16 Head
ARP rod bolts
ACL bearings
RS Machined Pistons
Eagle rods
P28 ECU + Tune
Going into a 2000 Civic SI
What do you guys think? am i set? This is my first engine build ever let me know if im missing something crucial or any tips. lemme kno thanks.
Old Jul 18, 2009 | 05:42 PM
SinsEvil666's Avatar
Default Re: B20 Vtec shopping list. Tell me what you think.
I'm not sure what Oil & water pump comes on the b20z...but on my b20b i know i need to upgrade to a GSR or ITR oil pump and water pump if u plan on high revving which seems like that's the purpose of this build.
Old Jul 18, 2009 | 05:47 PM
Speed_1's Avatar
what about the LS/CR-vtec conversion kit such as the dowel pins, oil lines etc. Gaskets? atleast plastigauge the bearing for clearance?
Old Jul 18, 2009 | 05:50 PM
blacc_ej1's Avatar
oh OK upgrade water pump. Is there anything on that list that seems unnecessary? like the block guard and such
NACvicSi's Avatar
Plus all new gaskets, rings (if your pistons don't come with new ones), like said above new water pump and oil pump also. If your head hasn't been rebuilt already might want to consider changing seals while it's out.
Old Jul 18, 2009 | 05:52 PM
NACvicSi's Avatar
You didn't say block guard. And yes I wouldn't bother with a block guard. If you are that worried about it you should get it sleeved now. Do you have a LS/Vtec conversion kit like the guy asked above? I have a brand new one I never used when planning my LS/Vtec build. If you need one let me know.
Old Jul 18, 2009 | 05:53 PM
blacc_ej1's Avatar
what is plastigauge? can some one help me out? lol
Old Jul 18, 2009 | 05:54 PM
blacc_ej1's Avatar
will a oil pump/water pump work off of a b16? or does it have to be off of a GSR or ITR?
Old Jul 18, 2009 | 05:59 PM
slowboost93's Avatar
a good headgasket is needed and go with type-r oil pump and get a gasket set from the local honda dealer
Old Jul 18, 2009 | 06:10 PM
Deetz's Avatar
Crazy Honda Guy
Have you bought in parts yet??
Not sure why so many people go to all the trouble doing a vtec conversion?
My suggestion:
B20Z short or long block
P8R head, yes, same flow as vtec head
used JR supercharger
This setup at 9 lbs would net close to 220whp and 200 ft ls tq
Old Jul 18, 2009 | 06:11 PM
Deetz's Avatar
Crazy Honda Guy
oil pump for B20, GSR and Type R are all the same
Old Jul 18, 2009 | 06:18 PM
blacc_ej1's Avatar
My suggestion:
well the thing is, i have the b16 engine and tranny in my em1. i think the b16 engine is a good candidate for b20v bc of the short tranny and the free flowing head. i want more tq so im trying to do this build. and no i did not purchase the parts yet.
Old Jul 18, 2009 | 06:23 PM
Deetz's Avatar
Crazy Honda Guy
I have an EM1 as well, in this case, why not use a gsr short block??
Old Jul 18, 2009 | 06:28 PM
blacc_ej1's Avatar
tell me more please? interested.
Old Jul 18, 2009 | 06:29 PM
NACvicSi's Avatar
Buy a GSR bottom end, put said B16 head on it. What more do you need to know?
Old Jul 18, 2009 | 06:30 PM
FaTBoY707's Avatar
GL hope you post the build up
Old Jul 18, 2009 | 06:51 PM
blacc_ej1's Avatar
so its a straight forward build? do i need anything else? just slap the head on the gsr block and im good to go? what kind of numbers will i expect with the gsr block?
Old Jul 18, 2009 | 06:58 PM
sanegb16's Avatar
is this an all motor or boost setup?
Old Jul 18, 2009 | 07:01 PM
blacc_ej1's Avatar
N/A
Old Jul 19, 2009 | 03:05 PM
blacc_ej1's Avatar
bump
Old Jul 19, 2009 | 04:16 PM
thumper64's Avatar
Why the B20Z block and not a B20B if you're getting higher comp pistons anyway?
Old Jul 19, 2009 | 06:08 PM
blacc_ej1's Avatar
Well that's just a shopping list, im going for the GSR block now with a b16 head. Will my B16A2 pistons fit in the GSR block?
Old Jul 19, 2009 | 07:25 PM
thumper64's Avatar
Is the Pope Catholic?
Old Jul 19, 2009 | 07:54 PM
blacc_ej1's Avatar
yes he is. lol
Old Aug 10, 2009 | 06:58 AM
supra-n-civic's Avatar
dislacement. the b20 gives you dislacement that the gsr dosnet thats why you donst just do a gsr swa
