03 600rr brake light stays on?
Old Jul 18, 2009 | 01:56 PM
jdmdc2boi12's Avatar
Default 03 600rr brake light stays on?
So i was riding today, when i got home.. i noticed that my brake light stays on the whole time.. what could be the problem?
Old Jul 18, 2009 | 02:23 PM
fatboy01's Avatar
Default Re: 03 600rr brake light stays on?
Is the light on and gets brighter when you touch the brake? Or does it just stay bright the entire time?
Check the switch on the brake footpeg. There's a spring attached to it. Make sure it's all adjusted right. If not the problem, check the switch on the front brake lever. Make sure when the lever is released, the button on the switch is fully released. Simple to adjust
Old Jul 18, 2009 | 02:30 PM
the light stays bright then entire time without using brake..
Old Jul 18, 2009 | 07:37 PM
DELETE POST.. Light switch wasnt plug all the way
Hardrock1l
Honda Civic (2001 - 2005)
Apr 25, 2017 08:20 PM
Z20rider
Nov 30, 2015 07:21 AM
riznup23
May 3, 2010 05:55 AM
cyclonedr
Oct 7, 2009 01:47 PM
jxhxb
27
Nov 25, 2007 10:25 AM
