trans problems help please!
Old Jul 18, 2009 | 11:12 AM
BuiltCivic99's Avatar
Default trans problems help please!
I need help i was at the track yesturday racing and i was probabl about 100 MPH maybe a little less not 100% sure but i was going to shift into 4th but i hit 2nd my car overrevved really high and i downshifted into neutral and now my trans sounds like something is rubbing and its louder in higer gears what did i do to my trans??
Old Jul 18, 2009 | 11:26 AM
Default Re: trans problems help please!
bump
Old Jul 18, 2009 | 11:54 AM
so i guess i moneyshifted...what damage did this do to my trans wut does it rubbing mean?
Old Jul 18, 2009 | 12:13 PM
ej1love's Avatar
B or D series?
Old Jul 18, 2009 | 12:53 PM
b16a motor with a b16 hydro trans...i dont think i hurt the motor at all something just sounds like its rubbing ..
Old Jul 18, 2009 | 12:54 PM
ej1love's Avatar
i know, just seein what tranny.
Old Jul 18, 2009 | 12:57 PM
so do u kno what the rubbing is?
Old Jul 18, 2009 | 12:58 PM
ej1love's Avatar
rubbing? not 'grinding'?
Old Jul 18, 2009 | 01:44 PM
no it def dosnt sound like griding...it sounds like rubbing..theres friction on something
Old Jul 18, 2009 | 01:53 PM
bump help
Old Jul 18, 2009 | 03:19 PM
bump
Old Jul 18, 2009 | 06:02 PM
bump!
Old Jul 18, 2009 | 06:10 PM
NACvicSi's Avatar
I did this once when I had just learned to drive stick. Destroyed my 2nd gear. Forever had the grinds till I swapped trannys. What do you mean by rubbing?
Old Jul 18, 2009 | 06:39 PM
its not a grinding sound at all its more like a rubber on rubber like a friction of rubber
Old Jul 18, 2009 | 06:43 PM
my friend said it could be my clutch but how would be overevving high **** up the clutch
throwout bering
Old Jul 18, 2009 | 06:46 PM
NACvicSi's Avatar
No idea what that could be. Any way to get a sound clip?
Old Jul 18, 2009 | 06:47 PM
NACvicSi's Avatar
Originally Posted by BuiltCivic99
throwout bering
Get in the car and start it. Press down the clutch pedal. Now release the clutch pedal. If you heard a noise with the pedal down to the floor it's a throwout bearing, if you heard it with your foot off the pedal it's a input shaft bearing.
Old Jul 18, 2009 | 09:05 PM
noise stops when i press in clutch
Old Jul 18, 2009 | 10:20 PM
NACvicSi's Avatar
Ouch input shaft bearing. Tranny has to be taken out and apart to get to it. Mine was going out on my car. I was about to replace it when someone offered a trade and saved me the work. Good write up:
http://www.d-series.org/forums/trans...ng-change.html
02NCAccord
Sep 10, 2013 04:24 PM
TeamProjectZero
May 7, 2010 06:24 AM
crx90rcr
Aug 24, 2005 08:03 PM
civicgl
Jan 20, 2005 12:57 PM
91b16acrx
13
Jan 8, 2005 12:06 PM
