ZC swap into crx si wont rev past 3.5k
Old Jul 18, 2009 | 10:36 AM
hwt101's Avatar
Default ZC swap into crx si wont rev past 3.5k
any help?
Old Jul 18, 2009 | 01:16 PM
jbrokos307's Avatar
Default Re: ZC swap into crx si wont rev past 3.5k
distributor is failing my car did the same just replace the whole thing otherwis u will just waste time and money rebuilding it
Old Jul 18, 2009 | 03:24 PM
4drEF's Avatar
Keyboard Humorist
New swap? might be the white wires are flipped backwards.
Spark plug wires might be 'leaking' and grounding out.
Old Jul 18, 2009 | 10:45 PM
hwt101's Avatar
yes new swap i will check those thanks
Old Jul 18, 2009 | 11:56 PM
likwid2u's Avatar
the white wires wont let the car start if flipped.............. try a new fuel filter
Old Jul 20, 2009 | 05:44 PM
brownsEF's Avatar
iacv check that out mine got disconneted woudnt rev past 3500
Old Jul 20, 2009 | 06:06 PM
TR_Accord's Avatar
iacv controls idle
Old Aug 27, 2009 | 06:16 AM
twentyhurtz's Avatar
kinda curious about this myself, one of my friends had a guy put a zc in his 91 hatch and it has a loose connection as well, if he mounts his ecu it won't rev past 3500 either, but if he lays in on the floorboard it will, let me know what you find out. its dumb, gotta be loose pin.
Old Aug 27, 2009 | 02:29 PM
89fodo's Avatar
dont know if it helps....had this same problem with my ls for months and couldnyt figure it out...turns out my crank harness had some bad wires...made up a new one problem solved
Old Aug 27, 2009 | 06:43 PM
SoB NiG's Avatar
Change the dizzy. I had that problem. Sounded like a 2step for an srt4..
Old Aug 28, 2009 | 12:25 AM
jenifertom90's Avatar
yes you can swap it.its really wise decision.
ERKK
12
Jul 14, 2009 04:05 PM
It's*BOLO!!
39
Oct 3, 2006 11:06 AM
cxjon
14
Dec 3, 2004 09:42 AM
poopycar
Nov 2, 2004 11:26 AM
civic2299
May 11, 2002 06:45 PM
