JDM ITR 5-lug VS. USDM ITR 5-lug ... any differences on the rear suspension?
Will the rear 5-lug off a JDM ITR work smoothly on a USDM ITR, or are there any necessary modifications that need to be made? I know theres a difference among the front suspension (32mm & 36mm axles), but I wasn't sure if there were any notable differences between the rears. Any info would be appreciated. Thanks in advance!
are the same 100% sure!!!! just the back side and the only difference with the front ones is USDM 32mm axles amd JDM 36mm.
the abs wiring goes up the trailing arm like a ek, not all had abs, some had a additional support welded in.
