Da swap from b18 a1 to b18 b1
Old Jul 18, 2009 | 07:29 AM
jdmtegra92's Avatar
Default Da swap from b18 a1 to b18 b1
Would everything wire up or would i have to convert it over?
Old Jul 18, 2009 | 08:24 AM
dinthanonh's Avatar
Default Re: Da swap from b18 a1 to b18 b1
what year DA do you have? if you have the 91 DA, yea you have to swap out wire harness
Old Jul 18, 2009 | 08:31 AM
jhammond_82's Avatar
Reject Papi
why would you? tons of people use those engines in their car without changing the harness.
Old Jul 18, 2009 | 07:03 PM
jdmtegra92's Avatar
91 use the harness from b18b1?
got it for cheap
Old Jul 19, 2009 | 07:32 AM
pitchblacksvt's Avatar
You need the conversion harness,the ecu from the B18, and change the wiring going to the distributor the instructions came with my conversion harness for going OBD0 to OBD1.
Old Jul 19, 2009 | 07:45 AM
M43STR0's Avatar
DA's are OBD0? call me retarded if I'm wrong, which i probably am, but...
I thought DA's were OBD1
Old Jul 19, 2009 | 08:30 AM
jdmtegra92's Avatar
this right
http://www.boomslang.us/obd0to1.htm
Old Jul 19, 2009 | 11:46 AM
vtecallday's Avatar
90-91 DA is OBD0
92-93 DA is OBD1
Old Jul 19, 2009 | 01:55 PM
M43STR0's Avatar
Originally Posted by vtecallday
90-91 DA is OBD0
92-93 DA is OBD1
Oh ok, thank you for clearing that up for me. Cheers
Old Jul 19, 2009 | 08:05 PM
seanbev24's Avatar
I'm assuming by your sig that your DA is a 91...
Whether you want to have the car obd0 or obd1, use the engine harness from your car.
If you want to keep the car obd0, use everything off your b18a and put it on the b18b. This includes distributor, intake manifold, injectors, exhaust manifold, alternator, etc. The only thing you should have to do for wiring is extend the wires for the fan switch, which is on the thermostat housing on the b18b instead of the back of the block on the b18a.
If you want to convert to obd1, use almost everything from the b18b and get an obd1 jumper harness and obviously an obd1 ecu. You'll need to rewire the obd1 dizzy or get a jumper harness for that too. If you want to use obd1 injectors, you need to get rid of the resistor box and solder on obd1 plugs. You can reuse the obd0 injectors if you don't want to mess with the wiring, there's no difference in performance. If you reuse your original alternator you won't have to rewire the plug. You'll also need a 4-wire o2 sensor.
Old Jul 19, 2009 | 09:29 PM
DB1_559's Avatar
you would have to convert it too obd-0,if your da is 90-91 if it 92-93 obd-1 plug n play only thing you will need to do if your useing the 94^ intake manifold is extend the map sensor wire
Old Jul 22, 2009 | 07:32 PM
jdmtegra92's Avatar
What about the sensors by the oil filter their different??
Old Dec 13, 2009 | 02:33 PM
cns-turbo's Avatar
id like to know also??^
sir.rexington
15
Oct 20, 2010 01:48 PM
SQ is the SQUAD
11
Sep 6, 2007 03:54 PM
koleslaw
Mar 24, 2007 09:39 PM
95_red_dc
Apr 19, 2006 10:01 AM
civicmark
Mar 30, 2003 09:19 AM
