CRX ZC DOHC
Old Jul 18, 2009 | 01:46 AM
SRZsmack's Avatar
Default CRX ZC DOHC
i have a DOHC ZC Engine and Transmission and im swapping it into my 88 crx hf,
i am wanting to know;
what axles will work in this swap ive heard 1988 integra axles will work perfectly.
and what ecu will be needed, will my hf wiring harness still work? dont i need to wire my distributor differently?
i am gonna use 89 si hubs will the integra axle splines fit?
what headers go on this engine is it still d series headers since it is still considered a d series even tho its dual cam? or will i need b series headers? '
thank you
Old Jul 18, 2009 | 02:03 AM
BiG ChOr!Zo's Avatar
Default Re: CRX ZC DOHC
http://thenew.gamesbbs.com/~dmoore/zc.htm
http://www.phatwhippincrx.20m.com/photo6.html
Old Jul 18, 2009 | 07:48 AM
jlicrx's Avatar
if you have a ZC transmission with intermediate shaft, you need to swap the knuckles/hubs for ones from 88-91 CRX/Civic DX/Si/LX and use 90-93 Integra axles - 86-89 Integra axles are too short
the best ECU to use is the JDM PM7 - the 88-89 (not 86-87) Integra PG7 will work just as well - the 88-91 CRX/Civic PM6 will work, but has rev limiter about 400rpm lower than the PM7 or PG7
use your HF wiring harness and make the changes to it at the distributor, like this:
http://www.zcspeed.com/HFZCwiring.pdf
you use the D-series header - it doesn't match the ports in the head exactly, so the best thing to do is grind out the top of the header ports to line up with the ports in the head - we have run the header without matching the ports and it doesn't make a whole lot of difference in how it runs
Ls1 FD3s
Oct 11, 2005 08:27 AM
The DX Rex
Sep 10, 2005 05:32 PM
teewhy55
Sep 6, 2005 12:12 AM
batman21
14
Mar 28, 2004 01:12 PM
akb16
Mar 10, 2003 02:38 PM
