adjusting jdm hid dc2 headlights
can anyone explain how i can adjust the beam of light from my hid's from left to right?
ive only found two bolts that adjust the headlights...one adjusts the projector up and down and the other adjusts the fog light up and down...
my projectors are both pointing to the left, how can i center them?
thanks for the help, i know there must be a bolt that adjusts them, i just want to know where it is and if i can get to it without taking off the bumper or fender liner
Are you talking about the "step" in each beam? If so, then because you have headlights that are made for roads in other countries (oncoming traffic on the RIGHT side of the road), the step will be higher on the left side...right in the face of oncoming traffic here in the states.
Check this thread out, in the middle are some pictures.
Hopefully that's what you're talking about, otherwise I wasted my time, haha.
can you post the link to the thread...i wouldnt mind seeing those pictures...
thanks
Whoops, didn't even realize the link didn't get pasted. When I get to my computer I'll dig it up and post it...I'm browsing on a phone right now.
Edit: Bingo -> https://honda-tech.com/forums/lighting-107/jdm-front-lamp-sae-dot-approval-problem-2486605/
I'm not sure about the JDM lamps but on the USDM's there are two separate adjustment screws, for both horizontal and vertical adjustment.
...and then those ******** in the UK have an electronic adjustment **** so you can adjust from inside the car while driving...jerks.
