fuel injector wire power gets bat voltage help.
Old Jul 17, 2009 | 09:29 PM
skaternak's Avatar
Default fuel injector wire power gets bat voltage help.
the power side of the fuel injector connector is getting battery voltage. i checked the ground wire and its getting 3 volts. is that normal?
Old Jul 18, 2009 | 06:55 AM
90Rexx's Avatar
Default Re: fuel injector wire power gets bat voltage help.
short to ground.... your injectors should always have power.... the pcm will ground the circuit when the injector needs firing.... if your reading voltage that means the circuit is grounded.
^^ someone else confirm this as im about 99% sure but not 100%
crispy93
Jun 10, 2009 02:36 PM
SLIPSTICK TIPPIN
Apr 4, 2006 04:05 PM
kholmes
Apr 13, 2005 09:49 PM
civickiller
Aug 14, 2004 03:24 PM
RuffRhyno
May 1, 2003 10:35 AM
