FS: PLX M-300 Wideband Kit
For sale is a slightly used PLX M-300 in car wideband kit. Wideband is very accurate and consistant almost identical to my tuner's wideband on his dynojet dyno (+/- 0.1). Wideband comes complete with 4 digit red display, bosch wideband o2 sensor, uncut harness/wires. This wideband has both a narrowband (0-1V) and wideband (0-5V) output to allow wiring to engine management systems for data logging. The following is specifications from the maunfacture:
Affordable, accurate, compact, feature packed, and simple to use are only a few words that describe our M-Series Wideband Oxygen Sensor Controllers. Designed in the heart of Silicon Valley, California with the highest technological standards, we bring you three wideband oxygen sensor controllers that meets the needs of every automotive tuner!
The M300 continuously updates the corresponding air/fuel ratio 10 times per second (10Hz) on its integrated 4 digit digital display. If the air/fuel ratio is measured below 10:1, the LED displays "rich," and if the air/fuel ratio is measured above 20:1, the LED displays "lean". The LED display is visible even in bright sunlight conditions.
Works with standalone engine management systems.
Accurate Air/Fuel Ratio <0.1, Fast Reaction
Advanced Sensor Self Calibration Circuitry. No manual calibration required.
Wideband LINEAR Analog Output (0-5V)
Narrowband Analog Output (0-1V)
32 MHz Advanced DSP Technology
Built in Resettable Fuse (No external fuse needed)
Sensor soft start circuitry, prolongs o2 sensor life.
Compact and Professional Design
"Plug and Play" Installation
ISO 9002 Certified Assembly
Real time wire data logging
SOLD!!
SOLD!!
DOHCtah
May 7, 2008 07:11 AM
DOHCtah
Northern California (Sales)
May 1, 2008 10:09 AM
DOHCtah
May 1, 2008 10:08 AM
tom@yoparts.com
Aug 27, 2006 05:07 AM
