help: 1st clutch change scratching noise.
Old Jul 17, 2009 | 09:42 AM
dannysolis92005's Avatar
Default help: 1st clutch change scratching noise.
i just did my first clutch cahnge on a 97 civic ex, it made a scratching noise before i changed the clutch i followed every step to chnage it and its still makes it. its competition stage 2 clutch. it cratches when i ease of the gass and am still on gear. thanks
Old Jul 17, 2009 | 11:09 AM
ek-g6's Avatar
Default Re: help: 1st clutch change scratching noise.
did you torque everything down to spec? Did you resurface your flywheel?
Old Jul 17, 2009 | 01:20 PM
yeah i toruqued the flywheel bolts to i believe like about 76 and the pressure plate ones to 19. no the flywheel wasnt resurface, it had some marks on it but i just cleaned it up. i ran my fingers through it and it seemed fine. should i have resurfaced it. what else can it be?
Old Jul 17, 2009 | 02:59 PM
Pothole987's Avatar
Scratching? like metal rubbing together?
Old Jul 17, 2009 | 03:17 PM
ek-g6's Avatar
it's always recomended that when puttin on a new clutch. If flywheel is not resurface, it can cause chattering, because the flywheel isn't even.
Old Jul 20, 2009 | 09:08 AM
Damn i think this is it! is there anyway that the tranny is bad? thanks for your help!
Old Jul 20, 2009 | 03:01 PM
Pothole987's Avatar
Doubt the tranny is bad. take it apart and either get it resurfaced or get a lightweight balanced replacement.
Old Jul 21, 2009 | 09:43 AM
thanks!
freshtyper
Jul 8, 2005 03:59 PM
Asahi
Aug 1, 2002 06:47 PM
turbo Si
May 5, 2002 08:44 PM
nfn15037
Oct 29, 2001 02:28 PM
