braille. no weight racing battery have you used it
has any one used the braille no weight racing batter, 6lbs $140
how was it did it last awhile and provide enough power? thanx
if you havent ever used it I dont want your opinion.
i have am odyssey pc680... works great... just dont let the car sit for more than a few days or it will go dead... i assume the braille has the same, crappy reserve.
I have used the 11.5 lb Braille battery in my car for the last few years. The 6 lb battery should be used primarily for racing. If you're not tracking your car, you'd be better off with the 11.5 lb battery which is still much lighter than stock but can be used as a daily driver battery which the 6 pounder is not. If you get the 6 lb just buy a battery tender such as this:
http://www.amazon.com/Schumacher-SEM...m/B0009IBJAS/2
MikeTV
Jan 23, 2005 08:30 AM
