Pressure on MAP (voltage is downing)
Old Jul 16, 2009 | 04:41 PM
PTVDesign's Avatar
Icon2 Pressure on MAP (voltage is downing)
Hi, all.
I have problem with Idle.
I check vacuum leaks, clean IACV, FITV, adjust TPS, install Fuel Pressure Regulator, Change the spark plugs and wires, check the ECU, Distributor...adjust IDLE (550-600 w/o IACV 780-800 with IACV, engine is F22B DOHC)
AND i have probleme in the MAP Sensor!
Where i check the voltage on IDLE i find the Voltage is downing from 1.04 to 0.92 V and engine is shuting down...
WHAT iS it?
big_jule
23
Sep 19, 2012 04:11 PM
twocross
29
May 3, 2011 01:03 PM
jaysalti
Jan 3, 2009 03:55 PM
talley2191
Jan 31, 2006 07:13 PM
IVI
27
Aug 29, 2004 09:27 PM
