Help.
Old Jul 16, 2009 | 04:15 PM
TheCivicMafia's Avatar
Default Help.
WHat Sand Paper should be used if i want to sand down to the metal
Do i need to clean the surface with something before i prime after sanding
And will a orbital sander work good?
Old Jul 16, 2009 | 08:20 PM
shocker911's Avatar
Default Re: Help.
why are you takeing to bare metal? easiest and fastest would be 35 grit on a high speed....and yea you would wanna clean with a wax and grease cleaner before primeing
Old Jul 16, 2009 | 08:58 PM
gorillafart's Avatar
Default Re: Help.
sand to the metal... use 36-50grit
yes u need to clean it be4 priming
DA/orbital sander will work fine.
Old Jul 17, 2009 | 05:07 PM
roadsqueegy95's Avatar
Default Re: Help.
i used 80 grit on a orbital worked pretty decent! and as stated before wipe down with wax and grease remover!
EG-SIXV-TEC
Jan 19, 2010 01:10 PM
Robb
Paint and Body
11
Sep 30, 2009 06:47 AM
Peter Brady onlyonweekndz
Nov 26, 2007 12:55 AM
tr0n9h
Jul 11, 2006 11:43 AM
SR20DE
Oct 24, 2001 01:38 AM
