Engine build issue
Old Jul 16, 2009 | 02:19 PM
jawsiiv's Avatar
Default Engine build issue
Hello all,
Building the block on a D16z6. When I put the new bearings on, pistons and allow with the crank, with the main girdle bolt on to spec, it turns with slight effort. No snags or slow spots just even smooth turning when I crank the block..... I put the oil pump and rear seal on, then all of a sudden the thing is a bitch to turn. Any suggestions, because I got the feeling it should turn some even with those items on. Used 1/2 drive and breaker bar yet still it did not turn.... THoughts and suggestions for this and initial engine break in are welcome...
Old Jul 16, 2009 | 03:00 PM
Ruben19's Avatar
Default Re: Engine build issue
are you using over size bearings. did you install the crank and rods caps correctly?
Old Jul 16, 2009 | 03:46 PM
jawsiiv's Avatar
the bearings are STD. I installed them per the Haynes Manual.
Old Jul 16, 2009 | 04:14 PM
jawsiiv's Avatar
Nevermind, I got it moving....
Old Jul 16, 2009 | 04:19 PM
Ruben19's Avatar
what was the problem?
Old Jul 16, 2009 | 06:21 PM
40mpg_dx00's Avatar
How long did it sit for the build? lacking lubrication?
nemesis.442
17
May 7, 2012 12:34 PM
turbodcxbro
Jun 23, 2011 05:56 AM
d16dcoe45
Oct 25, 2006 03:52 PM
the.hamburglar
Nov 30, 2005 03:16 PM
MugenB16A2
18
Dec 15, 2003 05:17 PM
