obd0 to obd1 d15b dizzy problem
Old Jul 16, 2009 | 09:33 AM
enjoi_hendrix's Avatar
Default obd0 to obd1 d15b dizzy problem
ok so a few months back i swapped a jdm d15b into my ef. it had already been converted to obd1 by the previous owner when they did a mini me(sohc zc block, z6 head) and the dizzy i was using just went out. i need to get a new dizzy to get it running so i can make it out to ia next weekend. i cant figure out which dizzy to use now. i tried a crx si dizzy, but figured out it had to be an obd1 dizzy. so i got a b7 dizzy, cut the harnesses, wired up my 7 wire circle harness to it, and the circle 2 wire to this one. it still doesnt wanna work. will i have to get a z6 dizzy and use it? im pretty clueless with all this so any information will be greatly appreciated. thanks in advance
Old Jul 16, 2009 | 09:41 AM
dephtone's Avatar
Default Re: obd0 to obd1 d15b dizzy problem
If you aren't using a jumper harness for the distributor plugs and cut the wires. The b7 distributor should work, are you not getting any spark?
Wiring for obd0 - obd1 dizzy
OBD0 OBD1
orange) (orange
white) (white
orange/blue) (orange/blue
white/blue) (white/blue
blue/green) (blue/green
blue/yellow) (blue/yellow
large white) (yellow/green (only color that is different)
black/yellow) (black/yellow
blue) (blue
Old Jul 16, 2009 | 09:46 AM
well when i originally swapped the motor, i had to do the same thing with the dizzy. cut off the harness for the dizzy that came with the d15b and wired up the harness thatd work with my wiring harness. the part that makes me think ima need a z6 dizzy is that the 3 holes from the b7 dizzy dont line up on the head. 2 of them do, but ones off. im hoping that i just need a z6 dizzy, and that they will line up, but im short on cash, and dont wanna have to buy it and it not work. all the wiring was done previously, as far as the jumper harness goes, so im tryin not to have to mess with it at all, so i dont mess anything up. but it was running fine before it went out
Old Jul 16, 2009 | 10:12 AM
team2dcrx's Avatar
yeah you need a z6 dizzy fasho
its the only dizzy thats gonna line up and let you adjust your timing
dephtone is correct on the wiring
Old Jul 16, 2009 | 11:02 AM
so youre saying that all i need is the z6 dizzy? im just trying to get all the details before i drop the cash on one. im a very unlucky person
Old Jul 16, 2009 | 02:21 PM
rustbucketrex's Avatar
D15B vtec uses the same distributor as the D16Z6, a TD-42U.
Old Jul 16, 2009 | 06:02 PM
i got my friend to disassemble a b7 dizzy and fix the z6 i was using. thanks for all the advice!
reek
46
Sep 12, 2010 05:01 PM
Iron_Forrix
19
Jun 19, 2008 03:58 PM
ludesrv
May 14, 2007 01:42 PM
hatchboy
13
Feb 6, 2007 07:04 PM
