cluster swap
Old Jul 16, 2009 | 12:26 AM
bakoCRX's Avatar
Icon2 cluster swap
putting a 95 gsr cluster in my 88 si crx but leaving it obd0 need help were do all 3 vss wires go to
Old Jul 16, 2009 | 04:03 AM
TwinchargedCRX's Avatar
Default Re: cluster swap
PIN 94-99 Integra COLOR FUNCTION 90-91 CIVIC/crx
Connector B / 16P
B1 Red/Blue Fuel gauge C710 #3 Yellow/white
B2 empty
B3 Yellow/Black Seat belt light Empty
B4 Green/Yellow Low fuel light Not used unless
you use a 90-93 integra fuel level guage
B5 empty
B6 Orange Speedometer Splice in with signal
from vss in the tranny
B7 Blue/Black Trunk/hatch open C710 #5 Green/Black
B8 empty
B9 Red Brightness C709 #9 Red/Black
B10 Red/Black Gauge lights C709 #8 Red
B11 Black/White color varies VSS Run the
electronic Vss to here and also attach to
the orange where b6 is ran..
B12 empty
B13 Green/Red-1 Silver Stripe Left turn signal C709 #12 Green/Blue
B14 Green/Yellow-1 Silver Stripe Right turn signal C710 #1 Green/Yellow
B15 Red/Green n/a not used
B16 Green/Red Emergency brake C709 #6 Green/Red
Connector C / 13P
C1 empty
C2 empty
C3 empty
C4 Yellow Dimmer C710 #2 Black/Yellow
C5 empty Cruise control empty
< C6 empty Empty empty
C7 Black Black Ground C710 #8 Black
c8 Yellow/green Brightness C709 #10 Yellow/Green
C9 White/Blue Battery C709 #2 White/Blue
C10 empty
C11 Yellow/Red Oil pressure C709 #5 Yellow/Red
C12 Green/Orange Check engine C709 #4 Green/Org
C13 Blue Tachometer C710 #2 Blue
http://www.angelfire.com/dc/oregonimport/gsr.html
Old Jul 16, 2009 | 04:04 AM
heres another helpul link
http://hondacrx881.tripod.com/gsrclusterswap.html
Old Jul 16, 2009 | 07:25 AM
gringo7718's Avatar
Power to any accessory (that turns on/off with the key)
Ground to any ground
The signal wire must be connected to BOTH
-ECU pin B16 (yellow/red)
-and the large plug on the integra cluster pin # 6 (orange)
https://honda-tech.com/forums/showth...&highlight=vss
rediye
Honda Civic (2001 - 2005)
17
Oct 6, 2023 03:10 PM
vtecn8ive
27
Nov 4, 2007 05:41 AM
quis84
Feb 7, 2006 10:14 AM
Gumbey75
Mar 25, 2005 08:20 PM
HatchBox
Nov 3, 2004 06:41 AM
