94+ teg spindles on 89 civic si
Old Jul 15, 2009 | 09:47 PM
nihad's Avatar
Default 94+ teg spindles on 89 civic si
would this work with out much problems.. or can just swap out the rotors and calipers..
Old Jul 16, 2009 | 04:35 AM
TwinchargedCRX's Avatar
Default Re: 94+ teg spindles on 89 civic si
the camber will be different . Not negative but positive.. u can use 90-93 DA integra spindles and brakes. Thats what im using on my CRX That will also allow you to run the aem Big brake kits for the 92+ civics
Old Jul 16, 2009 | 07:23 AM
EL Vap133's Avatar
Agreed, some people have said they have gotten it to work with adjustable camber kits but I just went ahead and used the DA (90-93 Integra) knuckles and used DC (94-01) brake components.
Old Jul 16, 2009 | 09:59 AM
1320whtrex's Avatar
The 94-01 Integra spindles can work but as mentioned above, a camber kit will be required. Skunk2 and some other companies, such as Revo, makes good front camber kits that should help soce this problem.
Old Jul 16, 2009 | 01:48 PM
nihad's Avatar
I am debating on what i should do i have a set of spindles from a 94 teg i got them for free all brake components .. But what i really want to do is the legend 2piston calipers and 11.1 rotors... And i looked at the 5 lug conversion i know there were some info on swaping out the hubs with 5 lug hubs and keeping the stock spindles.. 90-91 crx si spindles any info on this what hubs would i have to use and if i got the 5lub hubs would the legand caliper brakets need to be modified... like every one does with the 4 lug hub...
ohsnapzafingcu
Dec 19, 2006 01:32 PM
rexnst9
12
Sep 9, 2004 11:06 AM
turbod16y7vtec
Mar 4, 2003 08:01 PM
paulzy
Dec 19, 2001 09:33 PM
