Car died when it get hot.....?
Hello ya, I am hoping someone can tell me what is wrong with my civic LX. No the car does not overheat. The problem is when you drive the car and it gets HOT it automatic shut down and no check engine light pop-up.....Anyone know what is causing my car to shut down. Any help is very appreciate......
Is it a stock 94 Civic?
When the engine dies, do the dash warning lights remain on? If so, it could be a bad main relay or igniter unit in the distributor. If the engine does not restart immediately, check for spark and listen for priming of the fuel pump.
If all dash lights are off after the engine dies, then the ignition switch is most likely bad and must be replaced. Also check to make sure the battery connectors and ground wire are clean and tight.
EL Vap133
Apr 9, 2008 09:38 AM
