lookin for a little black relay box under steering column for crx that lights cluster
Old Jul 15, 2009 | 08:26 PM
okc's Avatar
okc
Default lookin for a little black relay box under steering column for crx that lights cluster
hi im lookin for this little black relay box under the steering column for my 1991 crx si... this box lights up the cluster and A/C bottun. if anyone have any idea wat this box is called plz let me know!!!!
Old Jul 15, 2009 | 08:27 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Default Re: lookin for a little black relay box under steering column for crx that lights clu
Wrong place.
If you read the forum rules at the top it has a WTB/FS for EF.
Old Jul 15, 2009 | 08:37 PM
801ef's Avatar
should be the dimmer switch that whole thing should be the relay
Old Jul 15, 2009 | 08:42 PM
LightWeightED8's Avatar
I think he's asking where its located not where to buy it. OP, if you are looking to buy, then yes, this is the wrong place.
Otherwise, you are looking for the illumination controller, which is connected to the steering column. The casing tends to crack so it may be loose and stuffed somewhere else. It is also connected to the dimmer switch on your dashboard or cluster hood. It's number 12 in this picture:
http://www.hondapartsdeals.com/hpa/z...e&x=1107&y=553
You'll see a few red/blk wires hoked up to it.
Old Jul 15, 2009 | 09:14 PM
okc's Avatar
okc
yes im just trying to figure out wat it is called because i found it on my friends crx and i am missing it... i took it off his car and put it on mine and found out y my cluster was not lightning up. so this box is called the illumination controller? can u help me find out the part number?
mark11017
Sep 27, 2010 09:17 PM
Antonio_P.R
Oct 21, 2008 09:52 AM
16yroldekownr
Jun 27, 2008 07:20 PM
Mfoehrkolb
Sep 19, 2007 08:59 PM
2fast4udude
Dec 27, 2004 04:25 AM
