94 rs e-brake not workin..at all
Old Jul 15, 2009 | 08:03 PM
801ef's Avatar
Default 94 rs e-brake not workin..at all
ok so i have a 94 rs and i pull the e-brake lever up and it does not hold soo i tighten the cables and it still wont hold i can hear it click at the caliper when i pull up the lever and let it down any ideas why it is not workin and how i can fix it? i really need to fix this asap..its preventing me from sellin it ha any help would be great
Old Jul 15, 2009 | 08:18 PM
ek-g6's Avatar
Default Re: 94 rs e-brake not workin..at all
How are the brake pads?
Old Jul 15, 2009 | 08:20 PM
801ef's Avatar
little more then half padding left
rotors are a litte worn but not much
Old Jul 15, 2009 | 08:28 PM
ek-g6's Avatar
I'm not sure what you meant when you said you tighten the cables. did you tighten from the ebrake handle?
Old Jul 15, 2009 | 08:33 PM
801ef's Avatar
yes
Old Jul 15, 2009 | 09:11 PM
801ef's Avatar
any ideas anyone?
Old Jul 15, 2009 | 09:24 PM
jasoncanseeoh's Avatar
maybe the rear sliders are really dry.
i had this same issue, and it worked for me.
also check if your e brake cable is loose when your rear wheels are off.
Old Jul 15, 2009 | 09:58 PM
801ef's Avatar
rear sliders?? pleasse more in depth detail maybe? lol wat do they look like how do i get them ..undry?
PreludePhill
May 5, 2006 07:22 AM
ts94acc
Oct 18, 2005 06:28 AM
cheaphonda
Apr 6, 2005 02:01 PM
JBBNJ609
Oct 5, 2004 01:02 AM
Type Goch
Sep 11, 2002 12:41 PM
