nothing happens when i turn my key to ACC
Just what the title says just realized that when the key is turned to ACC nothing works the radio nor the ac you anything that should be able to run on ACC doesn't, now when i turn it to the next one which is the III now my radio and ac turn on anyone know why nothing works on ACC and is there a fix?> thanks in advance
my guess would be the electrical part of the ignition(ignition harness) had the same thing happen on a coupe i just sold. if its in the ACC and your cluster lights aren't coming on( CEL ,BAttery, And whatever else lights come on with turn of key) and if you start the car and barely jiggle the key and it dies, then i'm about 99.1 % positive thats your problem....you should post in dept though what issues you are having exactly...i hope this helps. plus try searching, trust me, atleast ONE of these honda guys have had your same problem...good luck man
i told him that on ef-honda...he needs 50 bucks and like 15 mins worth of work lol it freaked me out when mine went i was like wtf??? i was checking everything i thought it was my alternator lol and then i held it SLIGHTLY in start where it wasnt engaging the starter and it was fine and then i knew it was out lol YAY for old electronics
Jjimenez157
Mar 3, 2017 05:35 PM
Kevins89notch
14
Jun 2, 2011 03:16 PM
