Relocating O2 sensor
Old Jul 15, 2009 | 05:10 PM
Memnoch's Avatar
Default Relocating O2 sensor
Simple and easy question for the gurus..
Currently transplanted a jdm b18b into my civic and its running on a chipped p28 (yes it does look for the primary o2), I plan on installing a dc header that has no o2 bung but the high flow cat I have still has an open bung for the secondary o2. The question is would there be any negative effects to relocating the primary o2 to the secondary o2 bung on the cat after the header install?
Now from the research I've done previously it leads me to believe this would not be an issue since all obd1+ o2 sensors on civics are heated, but would the primary o2 send improper readings to the ecu since its relocated further down the exhaust?
BTW the current primary o2 location is right before the flange on the header.
Old Jul 15, 2009 | 05:34 PM
cleansi's Avatar
Default Re: Relocating O2 sensor
chip the comp to delete secondary o2 sen what tune you running on ? yes it is right b4 the flange cocked to the passenger side a lil. like my... any ways not much sence to run it if 0bd1 i see that you said it looks for it tho. but if you located it after it will be fine and actually i perfer having mine further back for tunning issuies
Old Jul 15, 2009 | 05:43 PM
esean93's Avatar
It should be ok if it running a test pipe.
Old Jul 15, 2009 | 07:20 PM
Memnoch's Avatar
I can not understand the post below my initial post at all.. sorry dude
The car is running on a chipped p28 (ls basemaps) but that is besides the point...
The 'high flow cat' came with the car and that's what the kid called it.. it definitely resembles a cat and not a test pipe, but it still has the secondary o2 bung.. still think it would work?
Old Jul 15, 2009 | 10:44 PM
esean93's Avatar
no u should get a test pipe.
Old Jul 15, 2009 | 10:47 PM
esean93's Avatar
The other guy pretty much said it'll work but like I said ur ecu will get false reading with any kind of cat.
Old Jul 15, 2009 | 10:54 PM
Adam_b16a's Avatar
If you have a chipped ecu, you can edit the map so the ecu doesnt look for o2 sensors.
Old Jul 16, 2009 | 07:20 AM
Memnoch's Avatar
I know you can eliminate the o2s but I'd like to run atleast one o2 sensor for safety reasons on my daily..
Guess I'll have to buy a test pipe..
beastman@
May 19, 2008 08:39 PM
Griffins_Importuning
Aug 4, 2002 01:15 AM
Qwikrex
Jul 31, 2002 09:53 PM
Qwikrex
Jul 29, 2002 03:50 PM
