foglight cutout
Old Jul 15, 2009 | 12:43 PM
quirarte626's Avatar
Default foglight cutout
okay so i have these foglights off of the prelude 88-89 i believe (their the ones eveyryone puts on the efs) and i was wondering if they perfectly fit with the outline that comes with teh bumper..
or em i gonna have to customize it so the fogs could fit perfectly on ehtere?!
i need help quick! thanks
Old Jul 15, 2009 | 12:57 PM
SoB NiG's Avatar
Default Re: foglight cutout
Post pics as you go!!! I wanna do it i just can neva find 2 that match!! Good luck!
Old Jul 15, 2009 | 02:35 PM
crx_si-r's Avatar
Do this, take off your bumper and lay the fog light over the cut out and see how close of a fit it is. That is if you are using an 88-89 bumper 90-91 fit perfectly just cut along the line and you will be fine
Old Jul 15, 2009 | 02:40 PM
ALLxMOTOR EG's Avatar
Vietnamese!
This.
Old Jul 15, 2009 | 03:20 PM
okay i have another problem now..
me and my friend started doing the wirin..we did some mickey mouse **** but **** it as long as it works
we ran some wires from under the dash (fuse panel) thru the fender onto where the bumper is at..we test it out it worked...then we decided so start wiring the other side the passenger side but all of a suden nothing wants to work...not the driver nor the passenger. we hooked up the wires to the fuse panel and ran it...we were going to ground it to a bolt that's there but nothiN!
here are some pics..
Old Jul 15, 2009 | 03:35 PM
okay i think i know what might be the problem
the bolt that i tried to get ground out off for some reason it wasn't giving it any..
Old Jul 15, 2009 | 05:31 PM
grog's Avatar
Wow you should'nt use those twist connectors, they are'nt meant to rattle around in cars they're for homes. solder it or use crimp connectors. Try getting power from the two accessory slots at the top of the fuse box and add a fuse to all extra wires. also dont route your power through your switch it will most likely burn the switch out run the power to a relay (to run the foglights) and have the switch activate the relay. btw you might have blown the fuses you have your wires jammed into.
w0rdemon
Honda Civic (2001 - 2005)
Jan 14, 2009 02:34 PM
devilpuppy
Mar 18, 2005 02:33 PM
jdmDXrex
Dec 12, 2002 05:03 AM
FUP23
Nov 2, 2001 05:13 AM
