Transmission & Drivetrain Gearboxes, Differentials, Clutches
how to make a tranny survive at high rpms?
Old Jul 15, 2009 | 10:02 AM
JDogg's Avatar
Default how to make a tranny survive at high rpms?
Is there anything that can be done with a honda tranny to slow the wearing of the syncros at high rpm shifts?
i have a problem lifting to shift, its way more fun to leave my foot on the floor, obviously we all know that stock syncro's dont like this. they dont slow the gear enough and it ends up trashing the sleeve and gear.
certain fluid types seem to help but its not a solution, it just prolongs the inevitable.
Old Jul 15, 2009 | 12:09 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: how to make a tranny survive at high rpms?
either learn to drive, invest in ignition interuptor, run closer ratios, or invest in symchros.
OR have tranny convert to dog style, but that would be several thousand $$$$.
Old Jul 15, 2009 | 12:17 PM
JDogg's Avatar
i know how to drive, i rarely miss a gear, i just like to shift wot.
even new syncros dont last too long. I dont want to have to shift slower. I want the mess to live with 9000 rpm shifts. dog box is out of the question.
there has to be a way to do it.
Old Jul 15, 2009 | 08:04 PM
sackdz's Avatar
someone sells carbon coated OEM synchros. but like you said, prolonging the inevitable.
Old Jul 15, 2009 | 11:49 PM
Mista Bone's Avatar
D Tranny Guru
No way around it, you don't wanna spend the money, pack it up and go home.
Synchros are just brake pads, a wear item. Would you expect a OEM pad to work for and enduro at Road Atlanta????
It won't happen, you have to make the choice.
Old Jul 16, 2009 | 01:32 PM
Aquafina's Avatar
Clutch it.
Even with carbon-moly synchros and scuffed cones, you'll still wear the dog teeth on the gear and slider at an extreme pace. Synchro ribs will be worn faster and gear cone will likely glaze over.
Old Jul 16, 2009 | 02:00 PM
JDogg's Avatar
Originally Posted by Aquafina
Clutch it.
i didnt say i dont want to use the clutch.. i said i dont want to lift off the gas..
ever see howard from rlz shift.. thats about how it is
Old Jul 17, 2009 | 12:03 AM
MFactory's Avatar
Yup, full-throttle shifting
Best you can do is change to Carbon-Moly synchros, and keep replacing them every 10-15 passes or so if you want to keep your dog teeth and slider teeth in good condition.
For oil, make sure to run one that includes synchro/friction modifiers to help with shifting (most fluids with the "synchromesh" label do).
Old Jul 17, 2009 | 04:43 AM
SPOOLINmatt's Avatar
You can convert your b series tranny to dog engagement for $730-$750
Old Jul 17, 2009 | 04:46 AM
MFactory's Avatar
Yeah, the Liberty Faceplate option
Old Jul 17, 2009 | 05:18 AM
yes sir
Old Jul 17, 2009 | 07:18 AM
JDogg's Avatar
some how i dont see that as a great idea for my daily driver..
since you're the tranny expert.. what kind of fluid would you recommend for my s2000?
Old Jul 17, 2009 | 07:33 AM
yeah it would be about as bad as driving around on a "base map"
Old Jul 17, 2009 | 09:15 PM
Mista Bone's Avatar
D Tranny Guru
I used to flat shift my Z6 at 7000 rpm on nitrous, never left, just tap the clutch and shift.
Old Jul 19, 2009 | 10:41 AM
JDogg's Avatar
yeah, thats pretty much it.. at 7000 rpms a honda tranny will last forever, at 9000 not so much..
kihun_cha
Dec 3, 2005 09:12 PM
bseries_beast
Jul 14, 2004 10:51 PM
mikestypeR
Mar 2, 2004 04:44 PM
