Del Sol rear disk on EG
I'm picking up the parts to do rear disk on my eg with Del Sol rear disk. They come with del sol ebrake cables. I read you need to use the same ebrake cables as the rear disk you are going to use because of wheelbase and fitment. Does anyone know for sure which ebrake cables will work with this setup? Will the hatch ebrake cables work due to the fact that the wheelbase is close to the same? Thanks!
I Just read this on another thread. Anyone know anything about doing this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22Hatchy »</TD></TR><TR><TD CLASS="quote">Yaa mine did not some with cables. I didn't know which ones to use because I heard I can't use the del sol, cause there to short . I heard I can use integra or civic si. Thanks guys.
you can use the del sol ones you just have to extend the ebrake bar thing lol if you look at it you will know what i am talking about
</TD></TR></TABLE>you can use the del sol ones you just have to extend the ebrake bar thing lol if you look at it you will know what i am talking about
yeah, he means that you have to spin the connector where the ebrake lines connect with the ebrake handle.
if you've ever had it apart its the long nut looking thing
i used cables from the four door integra that my rears came off worked great
Oh your just talking a bout where you adjust it inside the car. Does this give it enough slack to use the delsol ebrake cables?
