got the h22a tuned something wrong?
stock h22a with 440cc injectors
only made 150whp and 129ftq???? seems low
i seen a h22a make 150whp on 3 cylinders
should i ask my tunner if something is wrong?
well i can tell you that there is defiently something wrong. do a pressure test to make sure you dont have a blow by in a cylinder.. also the only things that would help you in making more is maybe the I/H/E that you have and maybe shcams everything else will not help in making power. check your cylinders and make sure that you are getting fuel to all the cylinders also.
are you sure its hitting on all 4 cylinders? when i got my car tuned 1 injector wasnt firing and didnt find out til after i got home. made 125ish hp with a ls vtec on 3 cylinders lol.
my internet engine analyzer says it needs concrete information.
dyno graph?
peak power rpm?
peak torque rpm?
compression test?
leak down?
freshly tuned up engine prior to tuning?
check engine lights?
altitude? atmospheric pressure?
give us information we can actually use and you will get real help and dont be so concentrated on what the peak power the engine makes.
i went 14.0 at 97mph in a 98 prelude with 137ft lbs of torque so says the tuning tool....i mean dyno.
dyno graph?
peak power rpm?
peak torque rpm?
compression test?
leak down?
As it was already said, try to post dyno graphs so that we can judge from there. But just to gice you an idea, I tuned my stock H22 last friday on 100 octane and it made 200whp & 159lbs. torque. This was made with an almost perfectly flat fuel curve at 13.8:1 and 31 timing degrees.
what's the timing on it?
the torque/hp curve looks good just very low.
my b18cR has way more torque then that
something is off or your living in the himilayas
check spark, fuel and compression and come back
revhardallday
What was the condition of you car before you took it to the tuner?
Did it drive ok?
How was the gas milage?
Did it smoke? Blue or Black.
The numbers seem low, yes. But did you car have an issue before you even made it to the dyno.
How do your plugs look?
What is VTEC set at?
Did it drive ok?
before i went to go get tuned i was running a jdm p13 with the sock injectors had no problem and pulled hard now it feels like its holding back
compression is at 175+ on all 4cyl
new plugs
new injectors
new plugs
new injectors
