Dash swap
i cant remember where i seen it but here's a link of one pictured in a ef2 if that might help...!!!
http://www.socalcivic.com/forum/showthread.php?t=16932
i put a crx dash in my hatch. un bolt the 5 bolts holding the hatch dash in, pull it out. un bolt the 5 bolts holding the crx dash in. pull it out. swap them in, then bolt them in. you only have to modify the crx dash to fit a wagon or sedan.
the dash wont come out unless you lose the steering wheel or drop the column , its in the way
dash swap is easy.. no trimming needed into the Ef's as mentioned above.. just alot of little screws in akward places. and DO drop the steering column as also mentioned above.
Good luck!
thedudefromjerz
22
Jun 20, 2011 08:39 AM
90hatch2fast2pass
Jul 5, 2003 09:30 PM
