All four cylinders misfire...tried everything
Old Jul 14, 2009 | 06:54 PM
ncstater6b's Avatar
Default All four cylinders misfire...tried everything
I have a bone stock 1998 Acura Integra LS. It has 177,000 miles on it. The timing belt was replaced 10k miles ago and have never had a problem with it. In the last 500 miles I have been getting misfires on all 4 cylinders on a consistant basis. I did the paperclip diagnostic w/the CEL codes getting 71, 72, 73, 74 as well as had autozone check it with their computer and they got the same readings...random misfires on all 4 cylinders. My car can drive great for 20-30 miles and then all of a sudden drive like crap...stuttering and causing a loss of power for several minutes at a time, and then randomly drive perfect again. It happens both when the engine is warm or cold, and also while accelerating or cruising at a constant speed.
Things I have done:
New:
Spark Plugs
Spark Plug Wires
Dist. Cap
Rotor
Coil
Fuel filter
Fuel pump
PCV Valve
Main relay
Seafoam in gas tank
Checked for vacuum leaks
I don't know what else to try. I have read all of the forums and websites I can find on the internet and can't find a solution. Any ideas?
Thanks!
Old Jul 15, 2009 | 09:03 AM
all-mtr-teg's Avatar
Default Re: All four cylinders misfire...tried everything
Things I have done:
New:
Spark Plugs
Spark Plug Wires
Dist. Cap
Rotor
Coil
Fuel filter
Fuel pump
PCV Valve
Main relay
Seafoam in gas tank
Thanks!
My gsr had the same problem, it was a bad ignition coil. It may also be your ignition module. Find a distributor that you know if good and swap it with yours.
Old Jul 15, 2009 | 11:05 AM
94LS90RS's Avatar
I noticed you replaced the cap and rotor. Double check to make sure the screw on the rotor has not come loose. This happened to me and the car missed terribly. Make sure the rotor is on tight and put some lock-tite on the rotor screw.
Old Jul 15, 2009 | 11:58 AM
mouab18c1's Avatar
hmm weird my cousins ls is doing the same but drives like a champ even with CEL..
Old Jul 15, 2009 | 12:16 PM
racebum's Avatar
you double checked your ignition timing with the jumper jumped and the car warm right? a dying fuel pump can sometimes cause this since psi drops and you get a lean condition. normally triggers a lean CEL though. the idea about the ignitor is also sound. i would try a distributor swap.
Old Jul 15, 2009 | 12:21 PM
djtsmith007's Avatar
Guarantee its the ICM (ignition control module) thats the only thing can cause the misfire on all cylinders give the symptoms of driving you described. I had the same problem turned out to be the ICM. Plus my Acura Service Manual says the ICM is usually the #1 issue. from there its others but more likely than not its the ICM.
Old Jul 15, 2009 | 05:28 PM
ncstater6b's Avatar
The screw holding the rotor on is tight and is diamagnetic or w/e its called. I will buy an ICM tommorow and hope it works
Old Jul 16, 2009 | 01:58 AM
racebum's Avatar
you normally can buy a whole distributor for the price of that ignitor
Old Jul 16, 2009 | 04:11 PM
ncstater6b's Avatar
I have read that the Ignition control module would cause my car not to start at all if it was bad. That is not quite the symtom I am seeing...could it still be a possible cause for my random misfires?
Old Jul 16, 2009 | 06:07 PM
94LS90RS's Avatar
Could you post a video of the car running? How does it idle? I'm still with everyone else and its something wrong with your distributor. Did you try replacing the ignition coil? Its another known part to fail.
Old Jul 19, 2009 | 04:00 PM
ncstater6b's Avatar
The car starts up and idles perfect every time. The ignition coil has already been replaced and it didn't fix the problem. The misfires occur immediately after start up when the engine is cold as well as after it warms up...so I'm not sure if it is the ICM. I may try a new ICM however b/c I can't think of any other ideas other than possibly the ECU going bad..but I have never heard of one malfunctioning.
Old Jul 19, 2009 | 05:19 PM
1992blueGSR's Avatar
i had this problem in my da, i replaced my icm, that i got from autozone, and it still did it. i then tried a known working icm out of a buddys car and it was fine, so just because you replaced it dosent mean its working right. and if you bought any of that stuff at autozone, return it, believe me, i used to work there
Old Jul 19, 2009 | 05:26 PM
ncstater6b's Avatar
Did your car misfire while the engine was cold or warm, and do it randomly?
I have been buying my parts from Advance Auto...i have used 2 sets of plugs, 2 coils, and 2 distributor caps. While I know OEM would be best, I find it hard to believe that by trying two of each that they could be bad. I might have to try a junk yard first for the ICM b/c it is $260 from the toyota dealership...but $90 from autozone
Old Jul 19, 2009 | 05:47 PM
its only 43.99 at autozone part number: ja179
yes, mine would do it under any load if the car was cold, but it was only under high load if it was warm, if it did it at all, it was completely random, sometimes it wouldn't do it all day, but the problem never went away until i replaced it
Old Jul 19, 2009 | 06:09 PM
ncstater6b's Avatar
sounds exactly like my symptoms. I accidentally said Autozone...I meant it is $90 from Advance Auto. I will try to get an OEM one and hope that it works
Old Jul 19, 2009 | 06:20 PM
racebum's Avatar
parts store ignitors cost as much as entire distributors on ebay. just food for thought
Old Jul 19, 2009 | 06:39 PM
ncstater6b's Avatar
Just bid on a whole distributor on ebay...cant wait!
Old Jul 23, 2009 | 05:20 PM
ncstater6b's Avatar
Just put in a new Ignitor/Ignition control module and same symptoms. I noticed though that several of the wires in the distributor are missing some insulation. Is it possible that they are shorting out randomly? I had an additional CEL today that I didnt have last week that says "Catalyst system efficiency below threshold bank 1". Could my converter be getting clogged and cause misfires? Could gutting the cat fix this as a quick (temporary) fix?
Old Jul 23, 2009 | 07:38 PM
boarderwayne's Avatar
why dont you just get a new distributor like most people are saying and you wont have to replace every part of it. or try a known to work one from a friends car.
Old Jul 24, 2009 | 08:48 AM
ncstater6b's Avatar
I just bought a used distributor on ebay for $50 that came off of a 99 integra b18b1 obd-2 thinking it would fit my 98 Integra LS but the plug is different so I couldn't swap it out. The seller claims it should fit my car. WTF?
Old Jul 25, 2009 | 07:30 AM
TheAsian's Avatar
Disconnect your cat from the exhaust manifold< sounds like to me you have a cat that is clogging up. If you have a temp gun take a temp reading of the cat. and let me know what temp you got it to max temp.
All your systems could be caused by a clogged cat and with that code you just pulled thats where you should start
Old Jul 30, 2009 | 05:02 PM
ncstater6b's Avatar
Update:
I put in some fuel additive because someone suggested that maybe I had bad fuel. My car now runs great with no misfires once the engine is warmed up, but when it is still cold it misfires just as bad as before. Any ideas as to why it is only misfiring on all 4 cylinders only when the engine is still cold?
Old Jul 30, 2009 | 10:00 PM
racebum's Avatar
engine runs rich when cold.. i actually had this happen to a friend the other day. his issue was a plugged fuel filter and at least one dirty injector. you can pull the screens out of the injectors and clean them, then replace the fuel filter. it sounds like you might be facing similar. since cleaner helped, you're on the right track. change the filter and pull & clean the injectors.
Old Jul 31, 2009 | 04:00 AM
ncstater6b's Avatar
The fuel filter is brand new with less than 1000 miles on it. How can I clean my injectors other than running injector cleaner in the gas tank like I have been doing?
Old Jul 31, 2009 | 08:17 AM
aemintgsr's Avatar
I would check for resistance in the injectors to make sure they are ok. i believe they should be between 11-18 ohms, and then check to see you get 12v through the injector's connector.
