Oil Pan gasket replacement technique
Old Jul 14, 2009 | 02:50 PM
dth0ng69's Avatar
Default Oil Pan gasket replacement technique
Okay so everybody has a different way of replacing the oil pan gasket, and how they apply RTV silicone, and if they even apply any at all. A 6 year honda tech from HT suggested spraying Hi tach gasket sealant on the oil pan and placing the gasket on the pan, then applying Honda bond to the sides and corner of the upper side of the gasket.
I was wondering what were your guys technique when replacing the oil pan gasket? what would you guys use to seal the gasket, and how do you apply it?
Does my RTV gasket maker work good for this job?
http://shop.oreillyauto.com/productd...egoryCode=2132
thanks for reading.
Old Jul 14, 2009 | 03:03 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Oil Pan gasket replacement technique
I buy PermaDry gaskets from FelPro, they do not require RTV and none of my gaskets have ever leaked on me.
Old Jul 14, 2009 | 03:05 PM
98civdx's Avatar
Master Detailer
oem gasket with honda bond on mine.
Old Jul 14, 2009 | 05:37 PM
dth0ng69's Avatar
wait so permadry gaskets form felpro really does require any rtv and gasket sealant? Is this really true?
Im planning to buy permadry gasket from felpro and was wonderng if I should buy a sealant?
Old Jul 14, 2009 | 06:00 PM
DO IT ON ALL FOURS
If it is a PermaDry then no. I have never seen a PermaDry require RTV. That is also somewhat why they are named that. They are reusable and do NOT require RTV.
Old Jul 14, 2009 | 06:05 PM
dth0ng69's Avatar
I'm sorry I don't mean to question you, or challenge your answer. I just want to make sure I do it right the first time so it can be my last time. But do you have any proof or facts that permadry doesn't require any RTV or Honda bond at all?
thanks for the feedback so far.
Old Jul 14, 2009 | 06:22 PM
gen2tegboi's Avatar
Fel-Pro PermaDryPlus gaskets do not require any adhesives and can be reused.
Old Jul 14, 2009 | 06:29 PM
dth0ng69's Avatar
ohh so fel-pro permadryPlus gasket do not require any adhesives, but the regular permadry gasket requires alittle bit? or sorry I'm confused.
Old Jul 14, 2009 | 07:49 PM
gen2tegboi's Avatar
All I know the PermaDryPlus don't need anything. Make sure you just get a permadryplus and you're good.
Old Jul 14, 2009 | 08:28 PM
dth0ng69's Avatar
okay so i tried looking for a permadry plus oil pan gasket for my 1998 civic cx, with a d16y7 and could not find it anywhere.. where do you guys find permadry plus oil pan gasket? I found the regular permadry gasket at autozone.. but anyone know??
lymanator
May 7, 2010 07:56 PM
dth0ng69
Jul 18, 2009 12:04 PM
Corporation
Aug 25, 2005 05:20 PM
James
May 11, 2004 01:38 PM
HankYee
Aug 19, 2001 12:30 PM
