@%&# bad camber
Old Jul 14, 2009 | 01:00 PM
iNfAmOuS_E46's Avatar
Icon5 @%&# bad camber
Hey guys I am on my palm pre so I can't post a pic of how low my car is I will assume it is a 3inch drop maybe more front and rear
I looked an it appears to have yellow springs (neuspeed extreme ??)
Well all four tires have terrible camber wear
I was looking at camber kits but don't know what to look for I know for the rear I will probably use the wicked racing kit
But what kit for the front that won't break the bank ??????
Thanks in advance guys
Old Jul 14, 2009 | 01:02 PM
Default Re: @%&# bad camber
Also pix of my car can be found if you search for threads I have made
So you guys can see how low it is
nathanong87's Avatar
spending more on the front end will save u more down the road on tires/alignments etc.
i'd say, go with skunk2
Old Jul 14, 2009 | 01:34 PM
I don't think skunk 2 makes a kit for accords
Old Jul 14, 2009 | 01:44 PM
tamadrummer1120's Avatar
No, currently Skunk2 does not make a camber kit for the Accord. Most Accord guys will usually go with Ingalls Camber kits. Hopes this helps. Please not that Toe will eat your tires up before camber. So if anything, right now, just get the toe adjusted if money is tight. Then go back and do the camber.
Old Jul 14, 2009 | 01:47 PM
Pm me ur email ill send you pix
Old Jul 14, 2009 | 02:00 PM
TheMuffinMan's Avatar
He knows where you live!
New tires and an alignment.
You can go much lower than you are and be fine with tires. You don't necessarily need a kit.
Old Jul 14, 2009 | 02:06 PM
You sure bro because it destroyed these brand new tires
Maybe blown shocks also ?
Old Jul 14, 2009 | 02:09 PM
You need a *good* alignment, a mom and pop shop probably will not cut it. Getting good tires that have good treadwear on them is another necessity. You can't throw a $20 tire and expect it to last as well as the $90 tires (my most recent were $150 a tire online).
Digital alignment with before/after and have the toe corrected to 0 degrees. If for whatever reason you want camber kits still, I would just do the washer trick in the rear which works just fine and can correct around 1.5 degrees of camber or so and a ball joint for the front. Ingall's or whatever.
Old Jul 15, 2009 | 10:22 PM
Hey muffinman you got aim or a cell # I have some questions pm me
Old Jul 17, 2009 | 05:16 AM
Old Jul 17, 2009 | 05:17 AM
http://hondamarketplace.com/showthread.php?t=2574645
more pix here
Old Jul 18, 2009 | 10:30 AM
anyone ?????
links ??
91EF919
15
Jun 24, 2009 07:15 AM
DKYamada
Suspension & Brakes
12
Mar 21, 2009 06:29 AM
blk94gsr
Feb 11, 2006 07:23 PM
98lsskunk
19
Apr 15, 2005 07:45 AM
integraver
May 10, 2003 04:52 PM
