GSR into 90 Std
Old Jul 14, 2009 | 12:55 PM
TougeCoupe's Avatar
Default GSR into 90 Std
I already search and didn't really find a good write up on all i need th change for the swap i just need insight on details
Old Jul 14, 2009 | 02:24 PM
jdmwannabee's Avatar
Default Re: GSR into 90 Std
it's like swapping any b-series motor into a 90std
buy aftermarket mounts, custom shift linkage, the proper axles, proper ecu
convert to obd1 and wire v-tec
bang the frame rail so alternator can fit
etc etc
Old Jul 14, 2009 | 02:28 PM
TougeCoupe's Avatar
Thats what I'm looking for icant find a right up fir estimate on a STD swap
Old Jul 14, 2009 | 02:43 PM
did you try google? it doesn't have to be specific to the STD model try this http://www.phatwhippincrx.20m.com/custom.html
you'll have to figure out how to get the iab's to work unless you swap to a s2 intake manifold
Old Jul 14, 2009 | 02:45 PM
88Hatchy's Avatar
Its the same as a DX swap, if that helps.
Old Jul 14, 2009 | 03:04 PM
TougeCoupe's Avatar
I thought that you had to do more work since it's was a STD and I already got the sk2 intake manifold
Old Jul 14, 2009 | 03:52 PM
D16SiHatch's Avatar
not really much different. like the dx, you will need to convert to mpfi. and also you wont be able to use the std hubs with teg axles. you'll need si,dx,ex or da teg knuckles.
Old Jul 14, 2009 | 04:51 PM
TougeCoupe's Avatar
Thats one of the things I was trying to figure out about the hubs
Old Jul 14, 2009 | 06:40 PM
cmdeoro's Avatar
I think all you need is Si hubs... then you can use the integra 90-93 axles.
Old Jul 21, 2009 | 07:09 PM
TougeCoupe's Avatar
now can i just order the hubs and put the assembly on my knuckles or do i have to get the dx,si or ex knuckles also
waparson
Nov 3, 2008 02:45 PM
bbrian
Dec 8, 2005 07:08 PM
aaronhume
18
Dec 20, 2004 09:46 PM
ekoms31
Oct 25, 2004 04:35 PM
doc804
Jul 4, 2001 12:36 PM
