Okay, so I think I want boost now... An uncommon question.
Old Jul 14, 2009 | 09:45 AM
Rude Awakening's Avatar
Daughter not possible
Default Okay, so I think I want boost now... An uncommon question.
Okay, my motor needs to come out in my BB6, obviously an H22A4.
I have been against boosting NA Honda, for the simple fact of sound. I do love the noise from an NA screamer, like a DOHC VTEC Honda or a last gen Celica GT-S.
As you know, turbo usually muffles a cars note, usually giving even a B/H/K/F a flat 4G63/SR20-like tone. I have been against turbo for that single reason.
But I have seen vids with GOOD sounding turbo Hondas. What is the secret to keeping the hight wail of a DOHC VTEC motor with turbo?
typical SR/4G
http://www.youtube.com/watch?v=GfWuFtS40_w
http://www.youtube.com/watch?v=j4YQlQyHZi8
http://www.youtube.com/watch?v=VpyDE...eature=related
Honda with flattened exhaust note, sounds like above:
http://www.youtube.com/watch?v=0qmwj...eature=related
http://www.youtube.com/watch?v=vmoCN...eature=related
http://www.youtube.com/watch?v=JkqXr...eature=related
The sound I want:
http://www.youtube.com/watch?v=PYvdn...eature=related
http://www.youtube.com/watch?v=FdijTTxWwWk
http://www.youtube.com/watch?v=MAEkblGNrr8
http://www.youtube.com/watch?v=AKuZZ...eature=related
Even this Evo doesnt have the usual Evo blat:
http://www.youtube.com/watch?v=d3tMg7O8O1M
The sound is big thing for me. I have spent much money swapping out/changing cars, and having to change stuff or fix issues with them. Since my Prelude is a fresh car with the motor recently put in (and must be taken out) I'm building this one. Screw prebuilt beat *** ***** like I have had before. Now I have a Prelude, not a Civic ot Teg, and I cant swap swap a Prelude with H22 like a Teg I had, throw nitrous on and be fast. The Prelude, while retaining AC/PS, full interior, and sound system, can ONLY be fast with turbo....so.
But basically, when I piece together a turbo, I need to know which combination of parts gets me an enigine note not muffled by turbo components. If I were building a car that sounds like *** anyway (like a SOHC, SR, 4G, ect) then I wouldnt care.
Thanks for any help.
Old Jul 14, 2009 | 11:57 AM
Marauder's Avatar
Default Re: Okay, so I think I want boost now... An uncommon question.
not muffled??
well, doesn't matter which turbo you pick, a turbo reduces the exhaust note.
I think you'll just have to play with mufflers to get your desired sound.
I had a racing muffler on my civic when it was first turbo'd and it was VERY loud.
After getting hounded too much by cops, I switched to a more quiet muffler and haven't been bothered by the cops since.
The exhaust note will all depend on your final setup. Up to you to play with it.
Old Jul 14, 2009 | 01:03 PM
Bailhatch's Avatar
There is more difference between the way those were recorded than the actual cars.
Any car making big power sounds good so just do that and then play with different mufflers and wastegate routing if you really care about the sound that much.
Old Jul 14, 2009 | 02:19 PM
SPOOLINmatt's Avatar
do a 3" exhaust with no cat, resonator and it will scream.
my 4" turbo back is quite the wailer. lol
Old Jul 14, 2009 | 02:29 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Well I have a similar question to the OP's. I want my car to sound like it came straight from The Fast and The Furious, Oh Yeah I also want it to pull wheelies. How do I get that "mAd VtAkN" I keep hearing about?
Come on man, be serious you want to build your car around sound? As stated before, any car built well and putting out good numbers will sound good. Don't throw cheap parts at it and spend about 6-10k on your whole tubro setup and you will be golden, hittin' the ISH, and getting the B!tches, y0! (Not.)
Old Jul 14, 2009 | 03:05 PM
Turbo-LS's Avatar
Its gpoing to come down to many factors. the size of the turbo, what style manifold your running, the trim on the turbine wheel. the cams your running, the size exhaust and what mufflers your running.
my car sounds pretty damn good but my friends car just screams and we have similar setups. i thin kthe difference is im runnign 89mm stroke with an e cover turbo and he is running 87mm stroke with s cover turbo. the s cover is larger inlet so essentially acts like a larger intake and can allow some of the engine note to come alive.
also the length and placement of the dumptube as well as the size of the dump tube and wastegate will play a factor in this. there alot of variables but essentially a turbo car will be quieter than an NA car but you can make it sound pretty close. that first prelude that sounds burly is more than likely open DP or has an Ecutout
i also run two mufflers to keep things quiet out of the rear end of my car so i can hear my engine more so than the exhaust notes. i to like the sound of the vtec engine screaming along but it always sounds better when complimented by the whoosh sound of a spooled turbo and when the gate opens and you get the loud exhaust note hitting off the pavement
Old Jul 14, 2009 | 05:35 PM
I CRX I's Avatar
well heres a good solution to you question
http://www.youtube.com/watch?v=B-7ahG2hmeo
a sound that makes demons cry!
Old Jul 14, 2009 | 06:58 PM
NLR808's Avatar
http://s115271005.onlinehome.us/Dart2/MVI_0720.AVI
http://s115271005.onlinehome.us/Dart2/P2130003.AVI
from mister rmcdaniels theirs your loud noises
Old Jul 14, 2009 | 07:59 PM
Yeah because form =/= function for some. You know what, I like PS, A/C, and My Prelude's gonna have *GASP* 17 inch wheels!
You dont understand. The turbo on a built bossting spooling putting out good power will sound, the ENGINE's note will suck. There is a local K20/K24 turbo CRX that shows my point. This is the guy that did my first swap years ago, and put the motor in my Prelude, and will be doing the work.
http://www.youtube.com/watch?v=RDbUcwUN29E
turbo sounds good, engine doesn't.
According to everyone else, there seems to be too many viariables. I dont want to get it together, then sound like ***, and have to sell **** to local cheapskates. FUUUUuuuuu
Old Jul 14, 2009 | 08:52 PM
JShull's Avatar
That CRX you posted sounds awesome. He's running an open DP aka NO exhuast man.
Look into the turbo version of the WS2. 3in inlet and still sounds great. Try running open dump as well. My car used to sound nice and quiet until I hit boost and the wastegate opened.
Old Jul 14, 2009 | 10:15 PM
omiehomie's Avatar
up for more vids of disgusting sounding caR's ^_^
Old Jul 15, 2009 | 01:53 AM
I know he has no exhaust, I've been under that car. An exhaust tip attached to nothing is glued to the rear bumper, for appearance, because the car USED to be streetable. It still doesn't sound like its on motor. And I know the WS2 is one of those quiet deals. I'm basically trying to sound like I am on motor, just with spooling, if that makes sense.
Old Jul 15, 2009 | 08:25 AM
kidRookie's Avatar
OP is a ricer if hes worried about the sound a TURBO setup makes.
Old Jul 15, 2009 | 08:50 AM
DO IT ON ALL FOURS
Look at his Sig it says it all. I think he may be the guy from The First Fast and Furious that is retarded and looses his Dad's VW Jetta to Jonny with the S2000 and now he needs more sound to scare off Jonny's gang members... Oh wait the retard got shot in the end...
Old Jul 15, 2009 | 09:00 AM
kidRookie's Avatar
werd.. seriously, just turbo first ,and then worry about how cool its sounds when you rhittin crazy mad vtAk down the street!....
Old Jul 15, 2009 | 09:12 AM
locash's Avatar
You're in the wrong place if your main goal is the sound of your exhaust.
I'm not sure if I am dumber for reading this, or replying to it.
AsSanitySlipsAway
Mar 21, 2008 07:47 AM
nickgomez
Jun 18, 2007 11:56 AM
ptpgmfituner
Jan 2, 2007 07:02 PM
bonez817
Jan 2, 2007 12:46 AM
ThePunk
Feb 28, 2002 08:53 AM
