p13 vs poF ecu, does the poF support...
Old Jul 14, 2009 | 07:15 AM
$Tweezy's Avatar
Default p13 vs poF ecu, does the poF support...
p13 ecu vs poF does ukdm h22 ecu support...
yeea so my swaps done, and ive been trying to figure out the damn idle problem, it idles and dies and almost sounds like theres a miss. no cel, timings fine, had a certified honda mechanic friend of mine do the timing belt, balaance belt, water pump, balance shaft retainer, etc.... problem is hes an older guy and doesnt know much about swaps and jdm, ukdm, usdm, cdm you know, he knows how to fix them....
<b>?i got a JDM h22a from tiger, i know its jdm...
my ecu is for a UKDM h22 accord....</b>
i wired up the fuel pressure regulator solenoid, and the secondary intake solenoid.....BUT DOES THE POF ECU SUPPORT THESE? i thought these two solenoids were JDM ONLY, so would the ukdm support these sensors?
i wana make sure im on the right track before i buy a p13 ecu....
it just idles rough and dies, especially with the clutch engaged.... so i ran 5wires, vtec, vtec pressure sensor ( and its grounded out), knock sensor, fpr solenoid, and secondary intake solenoid and i made sure to connect the black/yellows from the two to switched ingintion so there hooked up right, im just wondering if this ecu supports these sensors and could possibly be the culprit?
Old Jul 14, 2009 | 07:16 AM
$Tweezy's Avatar
Default Re: p13 vs poF ecu, does the poF support...
its a jdm h22a obd1 into 91 accord lx....
Old Jul 14, 2009 | 10:37 AM
$Tweezy's Avatar
bump ive tried searching and ive come up with nothing besides the p0f is for the british h22 accord and i dont know if the ecu supports these sensors, so maybe my car would run better if i disconnected these 2 wires from the ecu????
Old Jul 14, 2009 | 02:03 PM
TheMuffinMan's Avatar
He knows where you live!
Get a chipped P28 or P06 and run a H22 basemap.
Postulio4jOO
Jul 30, 2009 10:08 AM
blackdelslo
Jun 20, 2004 10:10 AM
Mikey3000
Feb 27, 2002 10:53 AM
