What spark plug should I use?
Old Jul 14, 2009 | 06:58 AM
charlieboyhonda's Avatar
Default What spark plug should I use?
I there guys I'm building a d16 all motor high compression and i will like to know what spark plugs should I use? the comp is going to be 12.88:1
Old Jul 14, 2009 | 07:35 AM
Link16's Avatar
Default Re: What spark plug should I use?
Wait for someone else to chime in but I would say one step colder than stock, the higher compression would warrant a colder plug, I believe this is to ease off predetonation. I am sure someone will chime in with exactly what you need.
I would, however, recommend NGK's as they are cheap and good performing plugs.
-Alex
Old Jul 14, 2009 | 07:52 AM
can you give me a part number?
Old Jul 14, 2009 | 12:29 PM
civic accord honda's Avatar
NGK FTW
Old Jul 14, 2009 | 12:47 PM
Link16's Avatar
Originally Posted by civic accord honda
NGK FTW
This helps noone, it would help if you would stop running up your post count with useless posts.
OP: I am assuming you have a d16 from our year Si, so this is the part number for a stock ngk-BCPR6ES-11 and I assume that one range colder would be BCPR5ES-11. Hope this helps, a simple search on google provided me this information off of NGK's website.
Regards,
Alex
Old Jul 14, 2009 | 01:50 PM
Thanks and i'm using a ZC sohc so basicaly is a d16a6 (civic 90 si)
Old Jul 14, 2009 | 01:59 PM
BiG ChOr!Zo's Avatar
you can buy all NGK items from that engine direct and for cheap on www.sparkplugs.com
Old Jul 14, 2009 | 02:35 PM
LightWeightED8's Avatar
What don't you ask the person building your motor? And if you are building it yourself, why not ask people or search on what information goes into selecting a plug for a certain setup?
Old Jul 15, 2009 | 06:42 AM
jlicrx's Avatar
1 step colder is ngk-BCPR7ES-11 - the lower the number, the hotter the plug
Old Jul 15, 2009 | 07:41 AM
Beverly Stayart's Avatar
New User
Thanks for the recommendation of NGKs. I will check out www.sparkplugs.com to buy direct.
Old Jul 15, 2009 | 12:58 PM
Old Jul 15, 2009 | 01:44 PM
hisnibs's Avatar
Props to jlicrx for the sweet chart
Old Jul 15, 2009 | 05:26 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Good stuff Jlicrx.
Old Jul 19, 2009 | 01:00 PM
elf469's Avatar
X3
Dude seriously...that is an awesome chart.
FAmou5
11
Mar 2, 2010 01:16 AM
123Four
Sep 22, 2007 03:28 PM
nateg
Aug 3, 2007 05:44 AM
Quitripin
16
Aug 18, 2004 09:20 PM
stockcrix1616
Jun 13, 2001 01:14 AM
