How to remove these block plugs and studs
Old Jul 14, 2009 | 01:34 AM
vanny_david's Avatar
Default How to remove these block plugs and studs
My B20 block is basically a BARE block, no allen plugs and no studs~
I need to get all those little plugs and studs from my B18A blocks to my B20 block
What tools do I need to remove these allen plugs as shown in green (they have these plugs in every side of the block >__< )
and what tools to remove these oil pan studs ( shown in yellow)
Old Jul 14, 2009 | 01:44 AM
Default Re: How to remove these block plugs and studs
please move to tech/misc forum
thanks,
Old Jul 14, 2009 | 08:02 AM
bluedlude's Avatar
you need an allen key on a wrench for the allen plugs, and if you dont want to reuse the studs use a set of vice grips. if you do then thread two nuts onto the stud and loosen only the lower nut. the stud should break loose and begin turning out.
FYI always use some honda bond when you replace the plugs
Old Jul 14, 2009 | 03:25 PM
b19coupe's Avatar
THEUSED
Apr 19, 2005 03:10 AM
zCivic
Nov 15, 2004 05:17 PM
acy76
Mar 23, 2004 07:36 PM
whiteblurr
Feb 5, 2004 06:31 PM
