Best stock axles for D-series?
I keep breaking the autozone axles on slicks. I leave on motor and am on the gas before the 60' mark. I dont have the cash right now nor the desire to spend 600+ on a set of axles. Anything I can do as far as a better set of axles? I have an obx lsd and the car is a d15b vtec with 100hp or so worth of gas on it, full weight. Poly-mount inserts and a full race traction bar as well. Any options for me?
They are an old set of 24.5/8-14 MT's. The clutch is a Comp. Clutch stage 4 with a 8lb XTD Flywheel. How much air should I run? I have alot in them usually between 15.5-17psi. This is my first fwd I have ever had to the track. Most of the other rwd cars I run between 10-12psi.
Too much clutch and too much slick, too light of a flywheel.
20x8x14 MT's @ 12 psi on a 14x7 rim with a 12 lb flywheel. OLD Centerforce Dualfriction clutch. 13.09 @ 103 was my best, 1.81 60 foot, but I was on a 6" rim.
The slicks would spin about 1/2-3/4 turn at launch then hook and go, yuo are shocking the driveline too much, this breaking parts.
