crx SI cluster temp gauge not working (help)
well as the title says i got a 91 crx SI cluster on my 91 EF..when i took out the old oem DX cluster(no rpm needle) the temp gauge works perfectly..but then i put in the crx SI cluster and now the temp gauge doesn't work
..any ideas on how to fix the temp gauge in the SI cluster?the problem is in SI the cluster..thanks ahead you guys
ive had a couple of clusters that did this. it was the cluster itself, swapped in a working one from a buddys car and found out the problem was the cluster temp gauge section. goodluck!
civicdragger818
10
Mar 30, 2003 03:28 PM
