What offset for 235/60/15 DOT
im looking at rota RB but what offset will i need 35mm or 40mm??
Please inform and educate me
Car is a 93 gsr
PLEASE HELP ALL SMART COMMENTS WRITE ON A PIECE OF PAPER
Car is a 93 gsr
its going to depend on wheel width. i assume you are using the 15x7's?
my 15x7 +40 clear 225/50's at full lock and stick out just a little past the fender. +40 might clear the 235/60 but you could just play it safe and grab the +35. they will stick out farther but we are only talking about a 5mm difference so you probably wont even be able to tell just by looking
it doesnt matter, either size, they'll still rub. be prepared to jack the suspension up high and maybe do some cutting on the front bumper. I had the MT's on stock LS webs. I imagine with a lower offsett wheel, it may rub even worst due to more of the tire having to cross pass the bumper when turning (less tucking). someone could correct me on that.
I have some 15x6.5" wheels and I dont even know what the offset is and I run 235/60/15's. You can check out the link in my signature and see some pics of it. I do not have a lot of rubbing but I do have it full raised in the front.
good info, I am interested in running a 255/50 M/T Radial under a Callos Front End, anyone know what kind of offset I should be looking at for something like this? I dont think I will have any issues with the tires hitting the fender/bumper on turns with that front end.
BB6-213
Dec 25, 2007 02:05 PM
