engine biuld mot sure where it gose
i would like to know it anyone ever biult a mini me swap with zc pistons if so dose it run high compression or low im trying to go turbo lmk if their is a thread for this also do i use my crank or zc crank
If you are referring to the p29 or the pm7 pistons, yes it makes it high compression.
a6/z6 with pm7/p29 pistons will put you at 11.6:1 - 12.05:1 depending on if you use an a6 headgasket (11.6:1) or z6 head gasket (12.05:1) according to the D series compression calc. This is also assuming you are using stock a6 rods. It will vary depending on which bottom end you decide to use.
If you plan on running turbo DO NOT use these pistons. Use Vitara pistons, they are cheap and have more than proven themselves.
jimmy o.
Jan 6, 2010 03:11 PM
puertoricanboy90
Dec 2, 2008 11:02 PM
CALC!_JUST_du_IT!
Dec 27, 2006 12:01 PM
projectef
Jul 24, 2006 03:44 PM
